LSD options for my 335i are scarce and ridiculously priced, they also usually require some kind of customisation to shafts.
Yes, I'd like to swap an LSD but its not in the top 1000 things that I need to spend money on.
What I'm wondering about is one of these; https://racingdiffs.com/products/bmw-e46-e90-e92-e39-e60-lsd-conversion-set?variant=33548118491271
I've watched install videos and reviews and while they're not as good as a proper LSD they do provide a fair bit of assistance in keeping both wheels spinning.
I'm a little concerned about doing diff damage with it although this doesn't seem to be an issue for others.
I'd just like some opinions.
Christian
https://www.sau.com.au/forums/topic/485212-lsd-cartridge/
That takes me back. A friend of mine use to make these for ALFAs back in the 90s. It's a method with a long history, and even represents the way some OEM LSDs were done.
This is better than what my mate used to make because they have provided the wear plate to stop the wear being done on the LSD plate or the side gear. Saves having to put metal back onto gears if you get your hardnesses wrong!
In short....what could go wrong? It seems like they've got a good design and manufacturing process.
  • Like 1
https://www.sau.com.au/forums/topic/485212-lsd-cartridge/#findComment-7986144
I kinda feel like if it gives me another 30 - 40% traction (just some numbers thrown around on forums) then its going to be great. I'm not rocking big power, after everything is done on the car i'll be around 400HP. Also, if this destroys my existing diff (I've seen a video of one exploding but jury's out on the cause) then I'm only down a few hundred to replace.
https://www.sau.com.au/forums/topic/485212-lsd-cartridge/#findComment-7986185
On 19/01/2024 at 4:54 PM, fletch rb30 said:
Looks the same as the old 'Phantom Grip' units from early 00's
I know a few jokers who put them in fwd's and mostly resulted in lots of wear and the lsd effect wore off pretty quickly
Yikes.
Any RWD reviews for sensible owners?
https://www.sau.com.au/forums/topic/485212-lsd-cartridge/#findComment-7986208
From what I understand these are a direct descendant of the Phantom Grip units.
https://www.sau.com.au/forums/topic/485212-lsd-cartridge/#findComment-7986225
Tried to get up my mother-in-law's driveway on the weekend, its a very tight turn into a very steep ramp and I couldn't do it. The passenger side just spun and spun and I had to leave the car down the bottom and walk up. This will be a great test after I install the LSD conversion.
https://www.sau.com.au/forums/topic/485212-lsd-cartridge/#findComment-7986226
On 20/01/2024 at 10:16 PM, PranK said:
Yikes.
No rwd experience sorry. Just a few people I know with fwd nissans. Always worked out better in the long run to get a proper lsd head.
This was maybe 2003-2006ish
https://www.sau.com.au/forums/topic/485212-lsd-cartridge/#findComment-7986240
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
