Up for sale is a brand new set of ISR Long Tube Headers, part number IS-SSHD-VQ35 for a 350Z/370Z/V36/V35 NISSAN SKYLINE
Comes with the o2 harness extensions (early Gen Z33/V35 only, see the CZP link).
More info can be found here:
https://conceptzperformance.com/isr-performance-hgc-long-tube-headers-vq35de-vq35hr-vq37vhr-nissan-350z-370z-infiniti-g35-g37-is-sshd-vq35_p_32339.php
https://www.isrperformance.com/isr-performance-hgc-long-tube-headers-vq35de-hr-350z-g35-370z/
This right now shipped to Brisbane through CZP using PayPal is $1106 USD or $1725 AUD.
Price I'm selling for is $1600 ONO cash on pick up, Eight Mile Plains 😃
#VQ35DE
#VQ37VHR
#VQ35HR
#370Z
#350Z
#V35
#V36
#Z34
#Z33
#Nissan
#Skyline
#JDM
https://www.sau.com.au/forums/topic/485240-v35-parts/
Up for sale is a Series 3 ('06) V35 Skyline Coupe OEM bumper with optional cameras fitted (some wiring still intact, cameras are untested).
This was the final revised update for the V35 (USDM G35s referred to this as the Sports Bumper however this wasn't the case with the V35).
There are some scuffs and scratches.
Currently painted in K23 Brilliant Silver
Price is $650 cash ONO
Pick up Eight Mile Plains
#CPV35
#V35
#Skyline
#Nissan
#G35
https://www.sau.com.au/forums/topic/485240-v35-parts/#findComment-7986428
Up for sale is a Series 3, 2006 CPV35 front bumper (also called the Sports bumper in the U.S).
Whilst the top half is the same as the earlier Gens, the bottom half was redesigned by Nissan.
I've put a comparison picture of this (miscellaneous Google images).
As you can see, there are some scuffs and bumps and a split on one side.
I believe the previous owner had put front parking sensors so there are cut-outs for that along with the rego plate holder. Can be filled/patched and painted.
It's missing the tow hook cover as well.
Please note, earlier gen aftermarket lips do not fit this (unless you mod/trim but would better either to find a S3 specific variant or go custom).
Looking for $400 ONO
https://www.sau.com.au/forums/topic/485240-v35-parts/#findComment-7986429
  • niZmO_Man changed the title to V35 parts
Up for sale are a pair of JDM 2006 Series 3 V35 Skyline Tail Lights (also known as S2 Tail Lights as they are the second variant).
The JDM variant has the correct amber colour for the turn signals vs North America which has red.
One has a crack on the right hand corner. You could seal it if you want to.
Asking price is $600 cash ONO
Am able to post however buyer pays for shipping and item won't be sent until money has cleared first.
Pick up Eight Mile Plains 🙂
https://www.sau.com.au/forums/topic/485240-v35-parts/#findComment-7986865
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
