a hello from France to all the community of a great lover of the skyline for years
Let me introduce myself, my name is Christophe, 51 years old, I am an independent boilermaker welder.
I apologize because my English is not great so I am going through a translator for some sentences, I hope I can make myself understood
I have owned an R33 GTR V-spec for over 10 years now, not as extreme as some of you but for us in France it is a nugget worth gold because it was. not marketed.
it in the colors of that of gran turismo 3
I do the track with it has a small 2.6l of 570hp and 630 NM
unfortunately I broke my block a few months ago so I registered to find information on the construction of the famous RB30 with conversion of the RB26 cylinder head. because dear to us there are not many people who have made RB30s themselves...
Today I would like to have around 800 hp
if that tells you; I can give a description of my car because there are quite a few parts on it, from the chassis to the engine including the complete syvecs s6gp management
I hope the questions will be relevant and will not be repeated over and over again.
looking forward to discussing with you
christophe
Welcome Christophe, the car looks great and you can find plenty of information here about rb30 conversions including the famous PDF file with all required details
Hi Christophe and welcome!
Yep, as Duncan said there are lots of topics on the RB30 conversions. Where would you source and RB30 block though? Was anything delivered locally with this engine?
Car looks great!
thank you for your compliments.😍
hi duncan !! I'm not going to hide from you that I already searched the forum before registering..😉
hi prank !! I already have the engine, I found it on ebay a seller of Spanish wrecks for 1000 euros delivered it to me in my workshop
it appears to be original. I found an RTA but there is not everything on it to check the bass ratings of the engine so I hope to find or have my answers here.
It's apparently an RB30 S2 that was tinkered with. the cylinder head was mounted with a carburetor with two valves on the bottom of the engine, it had 4 valve impressions
Afterwards it is not very young but I think with a little elbow grease I should be able to do something with it
if not I would like to be able to come to your country one day just to be able to drive on your legendary Barthurst circuit in a v8 supercar or with your monstrous trucks
  • Like 1
we call it "dirty 30" down here hehe. Reliable blocks (as they were made in the 80's with poor fuel and oil control). Lots of R31/VL turbo people make 300kW from stock blocks.
But yeah if you fly down here, can hire a can and drive around Mt Panorama (Bathurst), as it's a public 60 km/h road when there's no events on.
thank you niZmo-Man but you're scaring me, are you telling me that the block I found isn't the right one in the rb30 series?! I would have difficulty building it compared to an RB30S for example?!
Afterwards I actually saw that it was rich and that the remaining oil was well burned...
this one was mounted with a large double body carburetor the cylinder head is new but the surprise was by removing the cylinder head and the pistons the lower engine was not new and the water passage I don't even talk about it ....
So this weekend I'm going to try to wash and remove the sandblasting tablet before starting anything if you reassure me about my block because now you're making me doubt
The block you have is fine, assuming the actual block is OK of course. It looks like RB30S is the carby Patrol version which was not very popular/not a very good match to a very heavy 4wd as an engine so presumably that is what you have; not sure how that turned up in Spain, but good find :)
You will need to consider turbo oil feed and return points, milling a suitable flat spot and tapping a hole for a second tensioner, and check the oil pickup vs your rb26 sump. You will probably need a 2wd/4wd adapter plate to mount the sump as 2wd sump bolt holes are different (not sure if that is true for rb30 from a Patrol, but I think it is). You might want to redrill the gearbox so the lower mounting points are still available as this is for track use.
The rest is all so straightforward it is like Nissan wanted us to do it :)
Duncan 🙏down here it is!! I feel better !!
yes it comes from a patrol y60
so actually I would like to keep my 4-wheel drive, in fact I vaguely looked at this story of adapted housing and I found expensive HI OCTANE DIRECT who are apparently the only ones to do it for 4 wheels! even if I could do it with time since I work with metal. (but sometimes you have to avoid getting pissed off to be productive)
after my crankcase is already modified with a raised greddy crankcase and internally I have a tomei partition and my strainer and already modified for my greddy crankcase so not even afraid of this step.💪
I have a milling machine in my workshop so it should be done for this modification side
so I also looked for the getrag r34 gtr gearbox (yes I switched to gearbox 6 on my r33 for a few years) manual because in vhc (historic vehicle the sequential gearbox is not allowed)
so I also looked for the getrag r34 gtr gearbox (yes I switched to gearbox 6 on my r33 for a few years) manual because in vhc (historic vehicle the sequential gearbox is not allowed) I noticed that the head of the 4 wheel drive return shaft doesn't have much space so it's complicated so I'm going to buy this plate and not waste time on it
This is my priority. while focusing on preparing the lower engine to accept my cylinder head and my Tomei Procam 272 camshafts to have a ratio of approximately 9.50, it looks complicated to me
so I have to pull my hair but I like it
Yes, the Nissan engineers didn't have the courage but did everything to ensure that others like you faced it. was impressed that they were told not to do it at that time out of conviction that it would not work
Edited by krysto_77
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
