I get this screeching / squeeking noise when I'm on maximum boost (0.8bar). On other boost level's it's fine but only on 0.8bar. I don't have a boost controller but its not spiking. Can anyone tell me what's going on? Is my turbo going to die soon?
Current engine mods are 3" turbo back, Blitz front mount, 2 BOV's (Blitz and stock), A'PEXi Power Intake, Walbro fuel pump...
https://www.sau.com.au/forums/topic/48526-strange-noise-on-maximum-boost/
If its anything like the shrill whine/squeel that mine has recently developed at a similar boost level - I think or at least hope its because of a slight exhaust manifold leak I have recently discovered....
hmmm....I hope so. The noise really only occured when I got my exhaust replaced. Do you know what's involved in getting it fixed?
Somebody will correct me if I am wrong and for you guys sake I hope I am but I thought a screeching type sound from the turbo was a sign of excessive shaft play.
The screech is the compressor wheel hitting the housing or something like that.
I get this screeching / squeeking noise when I'm on maximum boost (0.8bar)....
Wouldn't be acompanied by smoke comming from the back wheels and a tendancy for the rear end of the car to step out would it??? :)
Sorry - couldn't resist that one.
Check that it's not fan/AC belts slipping also.
I also had a screaming sorta noise coming from the turbo for the last month. I thought maybe the turbo wheels were scraping the housing. I sussed it all out, and found that all my nuts holding the turbo to the manifold were loose as! Gave them all a good tightening, and now no more noise!
So check that out, or perhaps the turbo gasket is gone.
I had this problem too, Mechanic took apart the manifold and pipes, all gaskets needed replacing and i had 3 cracked bolts holding the manifold to the block. I also got the turbo checked out at (Central Cost Turbo's) and it got the clean bill of health. I think i actually gained some GO! power form all the gaskets and tightned bolts....
It cost me a couple of hundred for parts and labour..... (Not including the beer Macca's and Smokes..)
Great Name Lazza!!!
L :P
definitely lose bolts on the either the exhaust to turbo or turbo to manifold.
if you leave it, they will eventually burn out the gasket in between if it already hasn't.
I don't think that they are burnt out yet as you are only getting the sound at full boost.
if it completely burnt out, you would hear it at idle.. sort of sounds like a lawn mower..
    • Is the 650rpm idle on the rb25det neo for stock cars only? I've never had my car before and after tuning it to idle at 650rpm when cold. Always idle's cold around 1100rpm, and then drops to about 900-950rpm. I've heard the r33 gtst's idle there.
    • Series 1 RB25DET 5 speed gearbox, push type, 1st and 2nd gear syncros worn, may need bearings. Comes with quick shift, Tomei gear knob, release fork, bearing carrier, master and slave cylinder. $850. Cusco Super Single clutch,assembly, 225mm, used, comes with a Direct Clutch solid centre 5 puck ceramic clutch plate. $290. RB26 cams used, excellent condition. $280. HDI GT2 intercooler, excellent condition, has 3 inch piping welded to inlet and outlet. $250. All items located in South Eastern Melbourne. Please PM me if interested.
    • Hi all, I’m currently running a str pipe hi low hks exhaust and downpipe. Was wondering if I change out muffler to a titanium one will it change the sound of the exhaust? Plus I have always liked the look of the titanium pipes … anyone have recommendations to one?    side note already have titanium intake pipes.
    • I looked up my other car that is a R33 GTST series 1.5. Anyone able to confirm what a Aero Form Bumper is?     (1G) 2 Door Coupe; (2GK + 11V) RB25DET; (4B) 2WD HICAS; (7F) 5 Speed Manual; (14G) Super Fine Hard Coat; (15U) Large Rear Spoiler + Aero Form Bumper + Rear Wiper (Aero Selection)
    • Ha ha, all good! I've almost caved in and realised I'm buying one.  I know myself well enough by now that I will start chasing ADHD butterflies half way through building it and not finish it so I'm better off spending the extra money buying one instead of making one just so I can get into straight away.  I would very much enjoy making one as fabrication is probably a strength and definitely a passion but I don't want that to be at the detriment to the car I'm ultimately building it for! There's some pretty good ones around for ~$1100 at the moment so I think I'll just go that way.  At the end I sell it or as mentioned, get another project to make further use of it! Thanks gents.
