I get this screeching / squeeking noise when I'm on maximum boost (0.8bar). On other boost level's it's fine but only on 0.8bar. I don't have a boost controller but its not spiking. Can anyone tell me what's going on? Is my turbo going to die soon?
Current engine mods are 3" turbo back, Blitz front mount, 2 BOV's (Blitz and stock), A'PEXi Power Intake, Walbro fuel pump...
https://www.sau.com.au/forums/topic/48526-strange-noise-on-maximum-boost/
If its anything like the shrill whine/squeel that mine has recently developed at a similar boost level - I think or at least hope its because of a slight exhaust manifold leak I have recently discovered....
hmmm....I hope so. The noise really only occured when I got my exhaust replaced. Do you know what's involved in getting it fixed?
Somebody will correct me if I am wrong and for you guys sake I hope I am but I thought a screeching type sound from the turbo was a sign of excessive shaft play.
The screech is the compressor wheel hitting the housing or something like that.
I get this screeching / squeeking noise when I'm on maximum boost (0.8bar)....
Wouldn't be acompanied by smoke comming from the back wheels and a tendancy for the rear end of the car to step out would it??? :)
Sorry - couldn't resist that one.
Check that it's not fan/AC belts slipping also.
I also had a screaming sorta noise coming from the turbo for the last month. I thought maybe the turbo wheels were scraping the housing. I sussed it all out, and found that all my nuts holding the turbo to the manifold were loose as! Gave them all a good tightening, and now no more noise!
So check that out, or perhaps the turbo gasket is gone.
I had this problem too, Mechanic took apart the manifold and pipes, all gaskets needed replacing and i had 3 cracked bolts holding the manifold to the block. I also got the turbo checked out at (Central Cost Turbo's) and it got the clean bill of health. I think i actually gained some GO! power form all the gaskets and tightned bolts....
It cost me a couple of hundred for parts and labour..... (Not including the beer Macca's and Smokes..)
Great Name Lazza!!!
L :P
definitely lose bolts on the either the exhaust to turbo or turbo to manifold.
if you leave it, they will eventually burn out the gasket in between if it already hasn't.
I don't think that they are burnt out yet as you are only getting the sound at full boost.
if it completely burnt out, you would hear it at idle.. sort of sounds like a lawn mower..
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
