Hey guys!
We're Junsei Auto Parts from Sydney and we remake discontinued interior trim, 1:1 identical to OEM quality.
We've been bringing back discontinued interior trim for the R32 and JZA80 Supra. So far we've remade the R32 Stereo Fascia Surround and the Dash Defrosters, pics below 👇
We're here to ask what discontinued parts do you want back? Not limited to any Skyline! Drop your suggestions and we'll see what we can do!
Check out our R32 parts here: https://www.junseiautoparts.com/collections/nissan-skyline-r32
FrontFascia-1.jpg?v=1695801053&width=990R32FrontDashVent_1of2.jpg?v=1691218334&width=990
Edited by Junsei
8 hours ago, GTSBoy said:
At least the hinge, if not the whole lid, for the armrest. Not the normal low height, longer armrest that was standard. The taller, shorter length one with the cupholders under it that was an uncommon option.
Like this OEM option? We can do that, we could definitely do the whole lid, OEM leather and all.
Nissan Skyline R32 OEM Optional Cup Holder BNR32 GTR NISMO JDM Interior - Picture 2 of 10
Yuh, I have that one and the hinge is broken and the vinyl on top is cracked from years of elbows. I have been meaning to put effort into doing a better job of repairing the hinge (already done once, years ago, didn't last) and retrimming the top. But new made replacements would be even better.
The hinges are very low science, basically just being folded plastic. Any effort spent working out what to do to fix it on this lid would probably (maybe only possibly, depends on whether there's any commonality) be applicable to the normal lid's hinge too.
  • Like 1
Would you prefer a complete arm rest lid unit or a cheaper DIY kit that includes vinyl and new hinge?
For me, just a DIY kit to replace the hinge and vinyl/padding. The rest of mine is structurally sound.
Whether you would find enough takers (for even that much effort spent) to justify the work is a harder thing to estimate, as there are very few of these out in the wild.
If you were to make the whole thing, including the armrest for the top part and the cupholder that replaces the original armrest, you might be able to sell them to people who would like to upgrade. If there are enough of them, that is.
20 hours ago, Junsei said:
Hey guys!
Nice work there, the fascia looks great!
Yeah that's a tricky thing to figure out. We'll do some polls to get some more info. Where should we post them?
  • 1 month later...
38 minutes ago, joshuaho96 said:
It's worth it because you can flip it for 1400 USD on Americans that can't look up part numbers for some reason.
And they also confess that they just 3D printed them! Which makes me wonder if they will buckle in the heat worse than the originals did. Perhaps I need to hire a Chinese hacker to get the print files out of Nismo's server?
Not necessarily, completely depends on how its printed and what material they use. i cant see Nismo using a $200 FDM printer and PLA
The R32 defroster vents were definitely on our to-do list, but now that Nismo announced that they're remaking them we're not 100% sure if we should as well, they did however state that the vents will be 3D printed, which may be the reason as to why its a 3 piece design rather than the original 2 piece design.
That being said we were planning on remaking these using Injection moulding which is how the originals would've been manufactured, and they were definitely going to be priced lower than what Nismo is currently pricing their vents. As for the material we were looking at using AES plastic, which is like ABS plastic but has UV protection properties.
As of right now we'll just have to wait and see whether the Nismo vents are up to standard or not and we'll go from there.
Edited by Junsei
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
