Hello everyone ,
I am looking for the height rating of the RB30, because I would like to know if mine has already been planed or not
mine placed on my marble is approximately 286 millimeters
and the shirt is 152 millimeters
 20240202_1731531.thumb.jpg.dc96187a2ac675b14bb874986f823c01.jpg    20240202_1727091.thumb.jpg.e24547ade9ded71044a5a3644c5a565a.jpg
Your measurement technique will never tell you the deck height. Tape measures are not accurate enough, and you need to measure from the centreline of the crank, not the bottom of the skirt.
I don't know what the correct dimension is. Hopefully someone will chime in with it. But in the mean time, buy yourself a good quality 1000mm ruler and a straight edge. The straight edge is to take the place of the crank. You need to bolt on the main caps, and measure from the top of the main bearings to the deck, and from the bottom of the bearings to the deck, and average those two numbers.
thank you GTSBoy,
I'm going to do as you told me with my rigid rules. afterward I did as it was just to see if my block is still valid or not, otherwise it won't be much use to me to work on it
It would only be better with your method thank you once again, I hope there will be people who will respond too I will see
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
