the headunit in my 2020 V37 seems pretty good but im worried About how much stuff its actually hooked into in my vehicle that if i upgrade im going to lose alot of that connectivity.
the screen shares everything by the looks of it and i want to run a sub and amp so if i can do it of the factory system that would be great if not im not sure what options i have.
One option would be to find the head unit line out to the factory amp, and intercept/use that as input to your new amp (have to wire up separate speakers of course).
I went through something similar with my old CU2 Accord Euro (has a factory 7-ch Panasonic amp, which gets fed by some weird built-in equaliser in the HU). Pain in the arse to try to keep it factory-ish (I went to the trouble of finding compatible connector on aliexpress and then wiring it all up).
yer so the AMP is in the back under the tray and the sub sits in the tray.
im thinking of unplugging the amp itself and checking what wires do what and just wire everything up from the styandard amp/sub loom.
just hope everything works as intended but im thinking there should be all the wires i need.
Yes will do.
watching a few Vids on the tube about a dude putting a sub it.
he is running it in the standard spot aswell with an amp.
looks like he runs RCA's from the headunit and power then uses a connector onto his old sub wires and sends them to what looks like a Control unit of some sort.
LC2
Not sure why he used this maybe the stock head unit has no woofer control?
but with a Mono block Amp i should not have any issues controlling it?
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
