Hey guys
For people with a built rb25, how much did u pay for the machine shop side of things like balancing and prepping crank, testing and resurfacing the block, cylinders bored out piston and bearing clearence measured etc. I’m assembling the engine myself and using my local machine shop but just wana make sure I’m not getting ripped off, Not parts cost just the actual service.
Cheers
https://www.sau.com.au/forums/topic/485282-rb25-machining-costs/
Occurred in 2021. f**kers raised the price substantially over the quote on the phone, and tried to force in extra work I explicitly didn't want. YMMV. But theres a reference for ya.
Didn't get it balanced and didn't need line boring.
Should have got it balanced (get it balanced).
Edited by CowsWithGuns
  • Like 2
I would look at getting the block checked for cracks and stuff before any machine work
It seems there's a tendency for the block to show some cracks around where the head studs go
There's a few threads about the cracks on this site
  • Like 1
I wonder how many people have had their block crack tested, found tiny cracks between the head stud holes and water galleries that are only visible with crack testing, then went on to use the block anyway.
The engine I'm slowly building, the block came back from crack testing with a couple of those cracks identified... the machinist told me those cracks were very common and not to worry about it. And if it was his block, he'd still use it.
I'd feel a lot better about it if a bunch of people here have used similarly cracked blocks without issues (say up to 450kw ish without issue).
  • Like 1
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
