Hey guys
For people with a built rb25, how much did u pay for the machine shop side of things like balancing and prepping crank, testing and resurfacing the block, cylinders bored out piston and bearing clearence measured etc. I’m assembling the engine myself and using my local machine shop but just wana make sure I’m not getting ripped off, Not parts cost just the actual service.
Cheers
https://www.sau.com.au/forums/topic/485282-rb25-machining-costs/
Occurred in 2021. f**kers raised the price substantially over the quote on the phone, and tried to force in extra work I explicitly didn't want. YMMV. But theres a reference for ya.
Didn't get it balanced and didn't need line boring.
Should have got it balanced (get it balanced).
Edited by CowsWithGuns
  • Like 2
I would look at getting the block checked for cracks and stuff before any machine work
It seems there's a tendency for the block to show some cracks around where the head studs go
There's a few threads about the cracks on this site
  • Like 1
I wonder how many people have had their block crack tested, found tiny cracks between the head stud holes and water galleries that are only visible with crack testing, then went on to use the block anyway.
The engine I'm slowly building, the block came back from crack testing with a couple of those cracks identified... the machinist told me those cracks were very common and not to worry about it. And if it was his block, he'd still use it.
I'd feel a lot better about it if a bunch of people here have used similarly cracked blocks without issues (say up to 450kw ish without issue).
  • Like 1
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
