Hello,
Looking for some help with a hesitation I am having with my 2003 Nissan stagea 250trs with a VQ25DET. It starts to hesitate under harder acceleration over 3000rpm. the power seems to cut in and out above that rpm range under load. No intake or exhaust leaks(smoke tested) and no check engine lights or codes. I will attach a video of my issue. Maybe someone has experienced this before? It is super annoying when I'm trying to merge and the power cuts in and out. It feels like misfiring but I have no check engine light. I put in brand new plugs back 3 months ago, this is a new issue within the last month.
Thanks again for your help in advance.
Well the video refused to play smoothly for me, so that wasn't helpful.
It is probably missing. No CEL is present doesn't mean that it's not missing.
Could still be ignition. Could be weak fuel pressure. Could be noisy CAS signal.
problems like that under heavy load is often spark related, either plugs or coil packs.  As above, the lack of a CEL doesn't always mean all is healthy on the ignition front.
    • this thread delivers, once again Skyline owners, our cars spend more time off the road than on the road
    • Some of the stuff the PDR guys in the states pull is amazing too. Instead of drilling a hole. They crank some insane tension into it. I actually DIY built a pulling bar myself that I used to pull the Subarus front end out with. About an hour's work, a bit of 30mm *3mm shs, and a piece of 5mm thick plate. Worked great!   But I vote replace it with a GTR rad support. And not going to lie, I'll laugh if a GTR rad support doesn't fit a GTt...
    • Sorry, that was with regards to the rather pretzeled corner of the reo bar. It's in such a state over the years that drilling a hole is probably preferable to bothering to unbolt the thing
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
