Hi,
I have a set of tomei procams thats been sitting in a new built engine for a few years on an engine stand. (Engine has never been running)
what do you think about all the dark/black spots/dots on the lobes? Was about to install the engine but inspection was performed before installation.
oil had been applied to the lobes, and there were still oil on them. Ive added oil to the cams a few times over the years.
https://www.sau.com.au/forums/topic/485294-tomei-camshaft-lobes-dark-spots/
Looks like a bit of passivated corrosion. Try to clean it gently with solvent and shop towels. Then oil it again before first crank. Then pull the oil pressure sensor and feed pressurized oil into the engine. Then unplug that and install a temporary mechanical oil pressure gauge and pull the EFI fuse. Crank the engine and verify it registers oil pressure. Let it sit for a few minutes and check sump level and adjust accordingly. Crank again without the EFI fuse. Then plug it back in and see how it goes. I would probably only run it for one heat cycle or less before draining the sump and oil filter to look for signs of mistakes. Stupid shit can break engines within 1000 miles so don't treat a rebuilt engine like OEM new break-in procedure.
  • Thanks 1
It's pitting corrosion. Iron gone, leaving carbon behind.
Should have been smothered in assembly lube, which is a good idea for its start-up lubrication benefits, but also is better at keeping moisture off the bare steel.
Probably just do as Josh said, but I'd bet there's nothing to be gained from the cleaning step.
You will have to be wondering what the bores look like too now.
Well, valve cover has been removed a few times and oil has been added to the cams so shouldnt been any corrosion.
Oil has been applied to the cylinders aswell so should be fine. But Will inspect before installation
    • So you're now accepting offers of 10% more than the cost of the turbo kit fitted?
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
