Fair enough mate. Good call on sending car elsewhere. As I said something doesn't make sense here and someone else taking over may answer a few questions or confirm what shop a has said.
Crank will more than likely be salvageable with a linish and doesn't need upgrading. They can handle pretty big power without issue.
You can get a spool kit like this for reasonable money. https://www.spoolimports.com/conrod-piston-deal/spool-rb25-neo-conrods-and-ross-forged-pistons?gad_source=1&gclid=CjwKCAiAuNGuBhAkEiwAGId4aheIUpkSk8p4WcqiPjrHVtQMD2GMG8t37rXkX6hfikjFRQZ-ohSbvhoC-DoQAvD_BwE
You already have a serviced head, head studs, timing kit and gasket. Add a few K in for machining and assembly. Will be over 5 k but will also have a known brand spanking new forged bottom end.
Just now, Murray_Calavera said:
But when you bought the car, wasn't it making 300kw at the time? Or did I misread something previously?
You can verify this with 5 seconds of your time and a laptop. I wouldn't be surprised if none of the engine protection was turned on. Even if you have no interest in learning to tune yourself, please at least plug a laptop in and see what has been setup... or hasn't been. It costs you nothing, takes almost no time and could save your motor.
Well according to the previous owners dyno sheet from when he originally did the build, yes it was 300kw. I never got it dyno’d myself after buying it until the works were done. The tuner its at now said the engine protection is on
Theyre the kit a mate of mine recommended to get if i go down that track. Appreciate the help, and will keep you guys updated on how it all goes and what happens. Unfortunately i don’t think it will get pulled apart for a couple weeks at this rate with the work load they have on
But didn't you drive it before you bought it? I'm guessing it was driving fine at the time you bought it?
Owner took me for a drive. He didnt drive it super hard when taking me for a drive. Started fine, ran fine, didnt think much would be wrong with it. When i drove it, it felt powerful, pulled hard when i gave it a boot, despite the turbo coming on fairly late at 4500rpm (owner’s preference). I would have been none the wiser besides the fact i decided to get a local mechanic/tuner to give it a full go over and service. Previous owner seemed legit, he also had an R32 GTR weekend car, didnt drive this one much anymore, was wanting to either get in the market for a R34 GTR, or have some extra money for his wedding later this year, so wanted to sell this. All work had been done 8000kms ago, was pretty much dead stock before, and i can see from his rego history the car was barely driven since he owned it and did all the work
7 hours ago, GTSBoy said:
Whilst all of that ^ could be totally innocent, taken together it sounds like all the alarm bells ringing. You're just going to have to go forwards, not look backwards.
Alot of people don’t let others test drive the car, so wasnt a hige alarm bell to me
Well, the key thing is still your budget (and time, but you've said you don't have much), and the fact you are happy with the existing 300kw for now.
If I were you I'd buy the 5k engine, sell the head (probably for 5k these days as its a 25 NEO), swap your head onto it and send it.
Then, as funds allow, collect parts to rebuild your now spare bottom end properly.
You can be fully serviced Neo heads for $3000 online, so don’t think i will quite get $5000 for it. I would probably end up just keeping the head for a worst case scenario down the line, best case is i have a new head to upgrade if something happens to the current one in the future, as i imagine these will get harder and harder to find
Your NEO head is worth quite a bit of coin, and since it has been serviced it is already in tip top condition. You could sell that and you'll have only a small shortfall for a used 2nd hand NEO motor.
Slap on a new head gasket, using major service kit, a few new seals here and there and you'll have a very capable motor to do 300kW ~ 400kW all day.
My NEO head has new valves, valve guides, upgraded springs and retainers, upgraded cams, and all new gaskets, i don’t see why it would be a good idea to put in a second hand stock head? Stock valve spring don’t like handling much past 18PSI of boost comfortably, so would be silly to downgrade to a stock head I would think?
It was just more what will require the least effort & cost to get your car doing 300kW.
If this was my car, I would just get a basic forged kit and fit it up, and if your bores aren't scored and within spec just get 86mm pistons so there's no need to bore out the block.
No idea who gave you that $20k quote, however it can be done sensibly for much less.
  • Like 1
I found a stock bottom end for $2000 which i might get instead of spending $5000 on a whole engine. No scoring, and crank and pistons feel solid with no play or movement so likely bearings are good in it. He said i can pull the sump off to take a look. Just need to decide do i spend $5000 for a whole engine and i will have basically a whole engine i can modify outside the car for a high power build in the future. RB25DET Neo heads arent getting any easier to find, and likely Nissan wont do the heritage thing they are doing for GTR components
Haven't read the full thread but got tagged so here I am, sorry to hear this happened.
Cheapest path forward is almost always buying a used running bottom end and putting your head on it or just buying a good used running motor and selling your head/keeping as spare.
Bills $1500 build is stuff of legends honestly, I am no slouch at finding stuff online and my XR5 rebuild was still over 4k re-using stock rods and pistons, but including machining and a replacement crank etc and that was doing the labour myself - machining was an easy $1500. I did do new water pump, timing, every seal etc etc but it adds up fast.
Forged build is always going to be 10-20k, depending on parts used etc.
You do not want to use much of that bottom end now it's had bearing go through it, if it has an oil cooler that's in the bin, check the pump for scoring etc so you may have to replace a lot of that stuff out of necessity (turbo also) depending on how much bearing material and how long. It cannot be overstated how critical cleaning is after a bearing failure, not just a hot tank, oil gallery plugs out, manually cleaning with brushes, compressed air, and tons of brake cleaner.
Not sure I'd want to do another build on an engine that spun a bearing unless I was not using a lot of the parts.
Full disclosure, not a mechanic or engine builder and I don't know heaps about RBs anyway, take all this with a grain of salt.
Your budget and timeline will determine best course of action, how much do you want to spend to fix this issue and how long can the car be off the road?
P.S. Didn't even check this for typos...
  • Like 1
the block I found for $2000 was from a engine that had blown a head gasket, is there a way to tell if there is damage done from the blown head gasket? The seller says the bores are not scored at all and the tolerances at the rod end indicate no spun bearings. I was going to pull the sump off and take a look at it to confirm. Just concerned that the blocks structure could be compromised from a blown head gasket and possible over heating? Or am I overthinking this?
I was going to be doing as many new parts as I can like heater core, oil pump, oil cooler, but not sure about the turbo as that is a huge chunk of the expense, and it currently has a high flowed factory turbo and didnt want to go upgrading the turbo just yet as that will mean new manifold, new dump, and likely a whole lot of fabrication work to the intake, and i just want the car running again to enjoy it, as currently its been in the workshop for as long as ive owned the f!@&king thing, but was going to have it cleaned out properly and the shop that will be doing the work is confident in cleaning it all up. But shouldnt the oil filter have caught pretty much all of it?
No. If there is loose metal, then it will be stuck all over the place. And if/when it shakes loose after the rebuild, it will cause damage to your new stuff. It's not to be contemplated.
  • Like 1
Yes deck surface can have soft spots, you would ideally check it for hardness (quick/cheap) but these blocks are not as prone to that as others.
Guarantee you the shop will not clean it enough, it's your job to ensure its minty fresh clean as it's your wallet.
Oil filter is not designed to filter that level of debris, oil coolers really cannot be cleaned out properly.
You will want to have the turbo inspected at minimum incase it's already scored and I strongly suggest fitting Inline filter to the feed.
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
