  On 25/02/2024 at 11:29 PM, No Crust Racing said:
If you are buying new, just get a spool kit, but better yet ask your engine builder what they like to use. I go with CP because my engine builder told me to. I also went Nitto I beams and CA625 rod bolts because my engine builder told me to. Research shows that's a strong rod/piston combo, but that's a 4 cyl trying to make more power than you air aiming for so the HP/L equation is worse.
Have a quick look on marketplace at least, you would be surprised what stuff comes up for dirt cheap.
Expand
Cheers man will have a look
  • Like 1
  • 11 months later...
  On 20/02/2024 at 6:47 AM, LjB123 said:
Hey guys. Really would love some guidance here, im stuck between a rock and a hard place and makes me sick that ive just had one thing after another go wrong on a car I purchased a month ago.
Initially showed an exhaust valve leak from a leak down test, got head off, serviced, machined, replaced a few valves that needed replacing and all the guides, upgraded springs and retainers, upgraded cams to Poncam Type B’s, put it all back together. Popped it on the dyno, made only 180kw at 20PSI of boost. Power dipped at peak torque, so not good. They found it had a slight knock on a cold startup, but went away after a couple seconds. Dropped the oil, and found little bits of metal in the oil and oil filter, great! So bottom end needs some attention now. They didnt want to just replace whats broken, they wanted to go all out forged internals (pistons, rods, rings, crankshaft), get it machined, new oil pump, gaskets, bearings, the lot. Reckon it would come to about $20,000 with a tune after all back together. Im not after a ridiculous build. Its a weekend car to enjoy driving and cruising, im not wanting to make 500kw at the wheels. Reason they wanted to do all new parts is so they could cover their workmanship under their warranty, if something old that wasnt replaced broke, it could become a big thing
Can i get some guidance on what I should do here? This is my first time getting into this stuff and the car has just been an absolute shit show from the get go, and makes me sick thinking how ive purchased this car and the engine needs to come out. There were no signs of this from the beginning that it had a bottom end issue, and i have not even driven it 400kms since buying it
Expand
Do you have a recording of what it sounded like at startup? Just curious to know what it sounds like.
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
