Hello my tuning friends
Just wanted to bounce some thoughts around here. What would you consider a normal time for fuel pressure to catch up to boost pressure?
Say your cruising at 4000 rpm at around 10% throttle, then you pin the throttle, how far behind the MAP pressure would you expect the fuel pressure to trail / how long would you expect it to take for the fuel pressure to catch up? Would you expect it to be linear, say the fuel pressure trails perfectly behind MAP by 2 psi and then when boost stabilises at the max setting, fuel pressure also stabilises?
Reason I ask, very recently the fun police inside my ECU said no no to this happening (see attached picture)
I've got the sad's looking at the data. Looks like my fuel pump isn't keeping up :(. Will have to think about long term solutions...
The silver lining is, the car drives fine. If you didn't look at any data you wouldn't know anything is wrong.
I installed this pump just over a year ago -
https://aeroflowperformance.com/af49-1057-525lph-e85-hi-flow-fuel-pump
Do we think the pump is starting to fail, or should I be looking at anything else in the fuel system?
When it was originally installed, everything was fine. I checked the 98 and e85 tunes, all good.
For quite a while now, maybe 8+ months I've been on 98 only and the pump has been keeping up. But now that I've put e85 in it (the tank is currently about 50% ethanol) the pump suddenly can't keep up. No idea what's changed in the past year to upset the pump.
I would not recommend using any of the aeroflow pumps. Very prone to failure.
*I use and recommend a lot of their products. Fuel pumps are still best to stay with the big player's TI, Bosch, Pierburg
  • Like 3
22 minutes ago, GTSBoy said:
It's less about the sock and more about what might have been shaken loose from the tank walls/floor maybe by E85 or summat.
Yep a thing for sure, in this case though I've been on e85 for many years. Maybe 6 or 7 years? Can't remember, but a long time now.
But yeah, looks like I'm going to have to swap out the pump for the 3rd time now, so we'll get to see what the sock looks like anyways.
23 minutes ago, Dose Pipe Sutututu said:
lol they are sexy.
My imaginary car would run a big boy electric fuel pump though. Maybe 2 of something like these in tank -
https://fuelab.com/91901-1000hp-in-tank-power-module-fuel-pump/p327
But knowing my luck, I'd find out fuel lab can't make pumps and I'd be pulling them out again anyway lol.
  • 1 month later...
I haven't logged any data yet, but I wanted to bounce this off everyone while I'm waiting to take the car out for a proper run.
So the car was very hard to start this morning, finally fired and I took it to Supercheap to test the battery. Turns out the battery was low on voltage (can't remember the exact figure) and down about 250cca from where it should have been. Even though their simple battery tester said the battery was "fine, just needs a charge" they replaced it under warranty, pretty happy with that.
Could a failing battery be the cause of the pump failing to keep up? The pump is pretty hungry, it pulls something like 20 amps from memory but I don't know how much this all matters when the car is actually up and running and the alternator is doing its thing.
Yeah, but maybe not. Maybe yeah. Maybe not. You know how it is. I mean, if the volts are low and the pump has reduced capacity, then it will maybe not be able to supply enough fuel to keep up with your peak demand, but it really shouldn't make it go lean as you're ramping up, then catch up again. The pump dynamics are (should be) a pretty instant trade off between flow rate and pressure, and even that shouldn't matter because it is actually the job of the fuel pressure regulator to take care of that dynamic, leaving the pump to see pretty much the same pressure and flow conditions any time the engine is running.
  • Like 1
Maybe go log your voltage vs. RPM as you doodling around town. The issue could be your alternator is cactus which has been supplying fluctuating voltage to the rest of your car thus killing your pump early.
  • Like 1
Should I be logging ecu voltage or battery?
Edited by Murray_Calavera
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
