Despite what Tao says, the OP6 highflow will indeed run only 10 psi if you really need it to. Mine is doing that right now (well, actually, it's doing nothing right now because my pinion bearing sounds like a broken end mill) because I haven't got a dyno (it also broke) to do the necessary after upgrading AFM and injectors. So I'm just pedalling it around on low boost right now. It is fine. I do suspect that it is in the wrong part of the comp map and making hot air and can only hope that it all gets a lot better once I can push it up to 18 psi or so. I suspect this because it pings like a motherf**ker if I turn it up to ~12 psi. Hence I suspect that it is hot. (I also have suspicions about my fuel pump going soft at the top end, for which I would also really like the dyno to be back in action!!).
Anyway, point being, you could put a highflow on without tuning it. Not ideal (for a completely stock tune) because it would be bitchingly rich and retarded. Mine was tuned to provide about 190 rwkW on the stock turbo at 12ish psi, so it's perfectly safe so long as I don't let it ping. It did so for a little bit immediately after I put the car back together until I realised why the check engine light was coming on! (Like, on the first drive!). Running it on the dyno would have been better, perhaps.
In case it is not obvious, I only have the low pressure actuator on this turbo and will want to swap it for a 14 psi or so one when I can.
  • Like 1
Expand
Yup, from my understanding, every time I install a mod such as injectors, turbo, intake plenum, it needs a tune updated every time unless I put all the parts on at once and do 1 tune then. I've got an aftermarket ecu and has been tuned already but as you mentioned the highflow would need a tune.
What is that ping that you're referring to, do you mean detonation and if so, does it make the same sound as when a knock sensor goes faulty and makes a "ping" type of sound? I used to have that sound on my other car until after I finally replaced the sensor after years lol.
Pinging is detonation, yes. It sounds like a bunch of angry little men with hammers beating away on the inside of the engine.
Pinging doesn't happen just because the knock sensor dies though. All that will happen in that circumstance is that if the engine does ping (and it shouldn't) then it will keep pinging because the ECU can't hear it. My check engine light was coming on because that's what the ECU does when (amongst other things, of course) it hears too much pinging and tosses all its toys out of the crib.
  • Like 1
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
