Hey guys. So my bottom end has a potential issue, engine comes out to drop the sump later this week to see exactly what, has a bit of a knock on cold start up that goes away. My heads were recently done due to a found exhaust valve leak, so upgraded springs and retainers, and upgraded drop in cams while it was out. Heads went back on and we found the bottom end was knocking at high RPM (not very loud as was heard through the knock box and ear muffs) when they were doing a dyno run with the new head on. Car hasnt been started up again since
I have the option to purchase a freshly machined and honed RB25DET block, with a R34 GTR RB26 Crank, Nitto rods, nitto oil pump, new head studs, main studs, new main bearings for $3500, will need to get my own pistons though as he used the pistons for his RB25/30 build he ended up doing instead, and has had the built block sitting for a while and wants to clear it out. Block had only been assembled for test fitment of everything, then pulled apart so he could use the Nitto Pistons he had in his RB30 build
OR
Get my current RB25DET Neo bottom end fixed up, possible machining, new bearings, new rings, etc etc. Wasnt looking to do forged internals but could go down that track
Was looking to make 300-350 rwkw for now, maybe 400rwkw, as I do have all supporting mods already outside the engine to go to that power (besides the turbo but will upgrade that while im at it)
Will i see much of a difference using the RB26 internals? I know the crank has a longer stroke, what advantages will I see and is it worth just getting the almost-ready-to-drop-in bottom end and going with that, or freshening up my stock Neo bottom end?
thanks in advance
https://www.sau.com.au/forums/topic/485318-rb2526det-neo-build-worth-it/
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
