Ik ik… I have googled and tried different remote tuners to look at the maps to see if they can spot an issue because I cannot find a physical issue, even Haltech looked at them, AFR’s are good everything is acting as it should supposedly. I’ve spent over a year trying to dissect this problem and countless nights. This car WILL NOT rev over 4.5krpm. I just want to finally drive my car. Everything that could be replaced, has been replaced atleast twice. Coils are new and been swapped twice, the CAS is brand new, injectors are new and fuel system is full AN with no leaks and steady pressure. Fuel pump is ran on its own relayed circuit, steady voltage. I have tried 2 separate new map sensors. All protective measures have been turned off in the ecu as well so there is no limiters to hit… Ect ect. You name it, it’s probably been gone over.    What Am I Missing!!
-Haltech platinum pnp, onboard map or Haltech 3 bar(have both), full 3in exhaust, pulsar gtx3076r, 1000cc id injectors, aeromotive afpr, fmic, ffi manifold, 44mm watergate, Haltech boost solenoid….All the standard stuff…
pretty average setup. Please help
Edited by Spooly240
Added details
Valet mode? Do you have a aftermarket alarm
Does your ECU have valet mode?
I know some cars and alarms have them and you need to do some switch toggling to activate and deactivate
If you do have an alarm google the brand and look for how to activate and deactivate it
Or, as stated above, Cursed by a wandering gypsie, built on a pet cemetary, etc.
@GTSBoy All the above you mentioned have been checked. Me and a couple others went through the timing a few times and no issues with mechanical or ignition timing, the exhaust is straight through, no cat. Ive set and checked timing of the CAS a handful of times ik the cas can’t be out or the car wouldn’t run at all. The car runs perfecctttt, except right in that 4500rpm zone
@morboost speedo is no longer in the car, I’m running a powertune digital dash, and all anti lag and other features are all off.
@The Bogan I believe the Haltech platinum pro does not have valet. I mean you could technically run a switch to switch between tunes but none of that has been done. Also no alarm is in the car at the moment.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
