I have a 96 r33 vpec that currently running 22psi and has 486kw on the wheels it's running on e85 and I'm getting about 90km from 3/4 of a tank
It's booked in at jem for a flex tune and maybe a eco/cruise day tune just so I don't have to stop ever 90km to fill up
Just wanting to see who out there has similar power and what millage U getting out of a tank?
Clip for attention
https://www.sau.com.au/forums/topic/485350-500hp-fuel-consumption/
Mixed driving, usually meet ups and cruise days consist of both
I just Purchased the car but it's chewing about 54L/100km from a rough calculation but when I fill up next I'll have a more accurate L/100 it's just i haven't hit the 100km mark yet for me to go full up to the first click
And it's only tuned ATM for e85 it's booked in for a retuned and a few different maps, plus flex fuel next month but I'm just interested in what others out there are achieving on their builds
Edited by [SKYHI]
All good mate. No need to worry about actually hitting the 100 km mark, just zero out your trip meter the next time you fill up. Then whenever you decide to refill again, fill up the tank and post up how much fuel you used and the km driven.
As for burning 54L/100km, I'd be amazed if that was the actual figure. If that was real, that is batshit crazy rich and I'm amazed the car runs well. We really need the actual numbers to be able to give proper feedback.
Do you have a wideband o2 sensor in the car? Can you tell us what your cruising AFR's are like?
  • Like 1
Last year, I went on a couple of trips with my mate who has a 500hp R34 GTT sedan. I have a stock R34 GTT coupe. When it came to fill-up time, I was shocked to see we were putting near-identical amounts in. On these trips, I drove a lot less efficiently than him - keeping the revs higher - and being considerably more aggressively on back roads. Justification: it was Japan and gasoline is as cheap as piss.
My car doesn't have any fuel consumption related issues. I can't remember exactly what I can get from a tank but roughly 4-500kms seems about right.
As far as my friend's motor is concerned, I don't know the precise details of his build but it's something along the lines of: stock bottom end, tomei pon cams, bigger hot side, injectors, Nismo fuel pump, front-facing plenum and Nistune.
  • Thanks 1
Depends on how you’re driving it but that seems far to rich, for reference  I was able to get 330kms to a tank before it literally ran out due a faulty fuel sender telling me I had half a tank, that included a trip to roll racing
  • Like 1
  • Thanks 1
Yeah there is soemthing going on the with calcs, or may be the fuel sender and/or odometer is not working properly. E85 will use a fair bit more fuel, but that is like 30% more not 200% more :)
Off boost your car is pretty much like any standard engine (noting it probably has cams which would decrease the efficiency a litte). My 400kw stagea gets around 12l/100 on highway driving on 98; not great but not terrible
  • Thanks 1
My old 500hp R33 25/30 boat used about 20 L/100 Km around town, and about 15 L/100 Km on the Hwy on 98
Currently my 500hp blown LS1 in a Dunnydoore uses around 25 L/100 Km around town, and 12 L/100 Km Hwy on 98
I'm assuming your fuel gauge isn't accurate
I hope so I'll find out next fill up true usage as I zeroed off the KMs last fill
Just need to get the blinkers back on the front front of the car before taking it out
But thanks for the rough estimates I does give me some sort of target I'll be looking at after tuning
Yeah it has the full haltech catalogue of sensors it's booked into jem mid next month so I can get more info from them just need to get a new muffler and resonator fitted before then looking at the sp mufflers 4" inlet muffler and res
You could go for a drive, plug in a laptop and log data. If you upload the data here, that would answer a lot of questions.
On 17/03/2024 at 7:53 PM, GTSBoy said:
I'd bank on no more that 15 if you're not leaning on it all the time. I get flat 10s on 98.
I should of said that's for a mix of driving around town with quite a bit of loud pedal and no highway driving. I figure most of us use our skylines as a means to a bit of fun.
I usually get around 20-23l/100 for the above type of driving with 315rwkw on E85. It would probably be a little better if my trips to work where longer (only 15 min drive), would waste a bit on cold engine enrichment.
I reckon I could get 15l/100 if I drove in full fuel economy mode. No loud pedal, just cruise. I'd rather drive a Camry than do that, lol.
  • Like 1
  • Thanks 1
What program will i need on the laptop ?
With all your Haltech sensors, I'm guessing you also have a Haltech ECU?
Grab the right software for your ECU from here.
https://www.haltech.com/downloads/
Here is a nice little quick start guide. When you setup the data logger, you can just log every channel to keep things easy.
  • Thanks 1
Yes the receipts from the previous owner says haltech 2500 thanks I'll get cracking and let U know the info I find in there
  • Like 1
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
