Hey, new guy here... my teenage son is into drifting, picked up an R32 manual coupe drift car. Trying to learn what I can about it, and work on it together to get it going again (currently not running). It's all a bit daunting, we're coming from dirtbikes so its a bit of a jump to this, definitely out of our comfort zone.
cheers.
https://www.sau.com.au/forums/topic/485353-brisbane-newbie/
Hey thanks! Yeah it's a bit of a basket case for sure, very rough, interior is pretty well stripped, no roof lining and A/B/C pillars, sunroof leaks, missing lots of switches and trim etc. Body panels are rough, had a bit of a hard life, chassis rails are pretty well stuffed.
It's cranking but no spark, injectors are pulsing. So maybe faulty ECU, ECCS relay or ignitor??? although I think the ignitor is OK. Or could be a bad earth or fuse or something simple??? It never is... the wiring is a bit 'how you going'. Got an auto electrician coming on the weekend to give us a hand. Can't just throw parts at it, parts are expensive!!!
  • Garret Turbo with HKS rear
  • Tial 38mm external wasegate
  • Spitfire coil packs
  • ARP head studs
  • PWR intercooler, radiator, oil cooler
  • Braided power steering and oil lines
  • Custom welded charge pipes
  • Blitz boost controller
  • PWR catch can
  • GKtech brake hardline delete kit
  • HKS coilovers
  • Bride seats
  • Walbro 460 fuel pump
The blue plate on the engine bay says E-HCR32 and RB20DET 1998... what's the go with 1998???
  • Like 1
https://www.sau.com.au/forums/topic/485353-brisbane-newbie/#findComment-7987891
Well, for a drift car it looks reasonably well cared for (from this far away). Of course it would be driven hard but the parts are better quality than average and some thought went into the front bar mounting/intercooler etc
You can check the actual build date using the japanese vin (hr32-xxxxxx) here: https://www.amayama.com/en/catalogs/nissan?_s=h
The australian R32 GTR workshop manual has wiring at the rear which covered all R32, so grab a copy of that; recent high quality scans are here:
I'm not as familiar with the rb20 wiring, but check the earth at the ignitor is well grounded, when the coil pack cover is missing that ground is often forgotten. There is also an ignition relay next to the ECCS relay near the ECU to check.
  • Like 1
https://www.sau.com.au/forums/topic/485353-brisbane-newbie/#findComment-7987894
Thanks so much for the wiring diagram, that'll come in handy for sure!!
Yeah looks good from a distance, and for a drift car it's better than what I expected, except for the rail condition, I expected that. Bit of bog here and there in the panels but not too bad, we've nicknamed it Bogzilla.
I'll make a new thread after the weekend to give an update, hopefully we can get it running this weekend.
https://www.sau.com.au/forums/topic/485353-brisbane-newbie/#findComment-7987899
On 19/03/2024 at 12:08 PM, Tim32 said:
Yeah the Drift R wheels look awesome. They are pitted though, wonder if I can fix that somehow.
Looks sandable maybe? I cant remember if its just polished or if theres a coat of something on it.
https://www.sau.com.au/forums/topic/485353-brisbane-newbie/#findComment-7988119
    • So you're now accepting offers of 10% more than the cost of the turbo kit fitted?
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
