This motor sounds like a beast i cant wait to see more info about it and how potent it will be compared to a VR30 and VR38.
Wonder if we will see many 400Z owners going for a swap upgrade.
Obviously its only Auto from what i have been able to read about.
these new nissan engines are beast platforms.
https://www.sau.com.au/forums/topic/485376-2025-infinity-qx80-vr35ddtt-450hp/
10 hours ago, niZmO_Man said:
VK56 came from the Patrol yeah,
Yeah, but it's not a good motor as used in the donor car. Low revving and low power, courtesy of tiny camshaft lobes, as per all other Nissan V8s.
You have to tear them to pieces and put them back together the way that god intended before they're any good.
I'm much more positive on downsized turbos these days. Probably not a fan of these V6 turbos because they're a packaging nightmare but an I6 turbo vs modern NA GDI DOHC V8 is pretty comparable these days in terms of general pain in the neck for some reason.
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
    • There's always "MIG it up and grind it back".
