Hi All,
Thought i'd post an official translated guide from Nissan on how to remove a Nitrogen Accumulator Cannister. A friend was kind enough to translate the official Japanese doco for me with no ambiguity. I've seen a few videos and articles of people spending days trying to remove it... We spent 10 minutes... Didnt even have to remove the Attesa assembly from the car.. All we used was an oil filter removal tool.
Common mistake is people dont depressurise the Canister before removal resulting it to be almost impossible to remove - similar to a air tight jar of pickles.
1. Depressurising the hydraulic unit
Must take pressure off from the hydraulic unit before removing the unit from a car body - Can be done by loosening front part of cannister (before the Hex bolt)
(Refer to service technical information no. 1891 for more detailed instructions)
2. Removal of the hydraulic unit assembly from the car body
Refer to the car service manual for the instructions.
3. Removal of the accumulator from the hydraulic unit
Loosen the accumulator using a pipe wrench while holding the thread part with rags to prevent oil spillage. Undo slow by hands ensuring the accumulator unit is facing downwards so that no debris would fall into the assembly unit.
4. Threads preparation before installation
Clean thoroughly to remove all excess glues left on the threads.
5. Installation of the accumulator unit
Apply 1.5-2.0 threads length of thread locker (three-bond 1324 equivalent) to centre position of the threads on the accumulator.
Apply "Nissan power steering fluid special" all over the O-ring.
Fit the accumulator unit into the hydraulic unit by hand with full strength then tighten using a pipe wrench holding a head section of the unit with set torque of
39-41 Nm. (As reference it is equivalent to 8 degrees or 5mm on circumference.
Refer to the diagram below)
From top (Apply "three bond 1324" / Head
section / O-ring)
NB: If you scratch the surface of the unit, re-paint with anti-rust spray.
6. Disposal of the accumulator unit
Follow the label instruction for proper disposal of the unit.
Edited by Deza3000
Thanks, that is a really valuable post, I've moved the thread to the DIY section and added it to the DIY threads index
I take it skipped step 2 and just loosened and removed it with the oil filter wrench?
No worries! Cheers.
Yep I skipped step 2 and just loosed with the oil filter wrench, wasn't too keen on disconnecting the high pressure lines. I did loosen the brackets from the mount and had it dangling so i had a bit of clearance.
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
