Good morning,
I'm looking for suggestions for a good tuner around the Gold Coast or Brisbabe area for a mild R32 GTR to be tuned.
I've tried looking around here and googling a bit, all I can find is old posts with workshops that aren't around anymore. I've read a lot of good things about Gavin Woods but as far as I can tell he's not around anymore.
I'm on the Gold Coast, so if there's one here that would be ideal, but also willing to drive to Brisbane for the right tuner.
It's just a relatively stock R32 GTR, looking for a mild safe tune. Any help and suggestions are appreciated, cheers!
Hi, I use 101 Motorsport and ages ago have used both PITS (Matt Spry) and GT Auto.  I think PITS was at Molendinar so probably closer for you.  The other two are at Slacks Creek.  You could try Ramsdell Racing - Sean use to tune my car as well.
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
