Apologies, but not willing to hunt through 21 pages of "Stagea Parts List".
I have a RB25DET from a (early, 1996?) C34 in my R32 GTS4, and I need a new Rocker Gasket Kit, including the washers.On the assumption that all 25s are the same, I got a Protorque GVC6100 kit, but it has the wrong style washers, and the gasket appears to be a bee's-dick short. Most kits don't clearly show the washers, so I don't know if they will work. I've found a Durapro GSRC3025K, but again not confident it has the correct washers (washers need to be basically flat, not the type that insert into the rocker).
I contacted my local Nissan dealer, asking if they could get the correct kit if I gave them the engine number. The can only search on a VIN.
There are kits on eBay, but they claim to fit 180SXs as well as Stageas / R33s / etc, so I'm dubious that they are the correct kit.
Anyone done this before? Maybe give me your VIN so I can quote it to the dealer.
Any help / guidance appreciated.
https://www.sau.com.au/forums/topic/485403-rocker-gasket-kit/
Being a 96 it would be a non neo rb25, so any non neo rb25 gasket should fit. If I was you, I'd be calling the likes of kudos motorsport , EFI solutions to ensure you're getting the right part and ordering a genuine Nissan gasket kit. Will be a lot cheaper than Nissan spare parts as well.
As  I said in OP, the grommets (washers) are different. I need the plain flat type that acts like a washer - the kit I originally got has the type that insert into the retaining bolt hole.
I'll give kudos a call Monday, see what they can do.
This is NOT the type I need:
genuine-nissan-cam-rocker-cover-bolt-seals-5pce-bag-fits-ca18-rb20-rb25-rb26-rb30-513_600x.thumb.webp.a52c651b103f2c7252e771d0b0536463.webp
That is the correct type on my stagea's rb25; they pull down about 50% in height as you tighten them, and the bonded metal part is the washer (ie, your pic is upside down)
Per this post, those are the ones I used on mine
This is how they sit, don't overtighten them
Posted (edited)
(upside down because that's how they were pictured!)
Aha! So it IS the type I need!
Actually found replacement bolts that come with a flat rubber washer from EFI Solutions (https://www.efisolutions.com.au/billet-rocker-cover-washer-retainer-kit-rb20-rb25 ) - might fancy-up the rocker covers with a set.
Edited by blind_elk
