Hi Everyone,
I’m currently searching for a part for my R33 GTR—specifically the Nissan 38341-03V00 Retainer, Side Bearing. Usually, I rely on Amayama.com to source original parts, but this time they informed me that the part is no longer in production. So, I’m reaching out to see if any of you know alternative sources.
Additionally, I’ve already checked JP-carparts.com, but unfortunately, they don’t have it either.
The reason behind my search is that the driveshaft joint (as shown in the attached image) has deep scratches. I unknowingly ran the car for too long without realizing it was broken and had no grease left. Consequently, the three pin bearings inside were completely damaged.
Now, I suspect that the bearing where the shaft goes in might also be worn. Although I can’t feel it with my finger, the markings on the end prompted me to start looking for a new bearing.
Any insights or recommendations would be greatly appreciated!
Best regards
https://www.sau.com.au/forums/topic/485414-asking-where-to-source-parts/
  • 4 weeks later...
Took it apart to get to the bearing found out i was wrong the bearing was pressed on to the diff side and the part i removed only had the bearing side, checked the bearing all looked fine took the shaft end to a shop and they recon it was movement from back and forth that made the marks and not rumbling about, so i just changed the seal and put it all back again.
On 4/8/2024 at 12:37 PM, winc said:
Hi Everyone,
Best regards
For future reference, I believe all that Amayama does is act as a middleman between you and Nissan. Go to your local dealership, ask nicely for a parts account (I get 15% off with mine) and you'll get better pricing.
Cheers,
    • Gas MIG for learning, I was able to weld up some nice 1.6mm tubs so you can do thin stuff easily enough. Then moved on to thick caliper adaptor brackets with the same machine, all good.  Arc/Stick is great for dirty garden work etc, but Gas MIG for starting on car stuff.  Jump on the NCR FB page and search ATP Tubs or GKTech caliper adaptors for pics/info. I'm no pro but it wasn't hard to learn. Be willing to grind and go again though if it's cold etc.
    • That's not a bushing!
    • Oh and I got myself a grandpa spec dash mat.
    • Ok, so first round of maintenance done. I didn't get much history with the car but I know it was well looked after. That isn't enough for me though, so ...  I had to do the oil filter housing gasket. It was leaking a lot, and also as part of that I did the anti-return valve and the VANOS oil line (from HEL).  But, then I got hit with the while-ya-in-there's. Did both accessory and A/C belts, tensioners and pulley. The accessory belt that came off had a huge hole in it, like somebody hung it up with a nail. The pulley and tensioners seem ok, so I'll keep those just in case. I did water pump and pump pulley. The water pump had a small bit of play so timing was good.  I also did fan clutch. I don't know how to test the old one but between the water pump and the fan clutch the car is running a little bit cooler (not much ~2 - 3 degrees maybe) so good result. Unfortunately the thermostat and housing didn't turn up in time so I'll shelve those. I have no concerns at all on the current ones.  Then I spent what seemed like 40 days and 40 nights bleeding the air from the cooling system. She also got new air filter, fuel filter and did a Mobil 1 change with oil filter. Hilariously, not an hour after telling my wife how proud I was of myself to be going slowly and meticulously and making sure everything was torqued and nothing missing I went and started it without the oil filter in. The car complained immediately of no pressure and after only a few seconds I turned it off and discovered a shit tonne of oil on the driveway. Sigh. I've driven it since and thankfully doesn't seem to be any problems. AND THEN during the test drive a ratchet extension fell into the battery area in the boot and JAMMED right next to the positive terminal and the car body. Like, just touching it made sparks and it was jammed in there. So, almost killed the engine and then almost burned the car to a crisp. Good start. This was the rails under the splash guards. So stoked, she's straight as and super clean. No rust anywhere. There was a heap of caked dirt that I removed but otherwise looked great. All 4 jacking points are perfect.   Next I want to service the gearbox. Sometimes it's a little reluctant to shift up and I'm hoping a fluid change will sort it. I also have 4 new rear subframe bushes. They're as big as a toddler. I'm renting a tool to help put them in. I can't wait for this because its a bit crashy back there at the moment.
    • Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon? NASA has their brain switched on and uses the metric system.
