98 ER34 GTT idle races, if AAC is unplugged, then idles perfect.
1998 ER34 GTT rb25det neo,
rpm's race at idle, around 1200 rpms, I cleaned MAF, AAC/IACV. no change.
if I unplug the ACC 2 wire plug, it idles correctly, around 900 rpms.
questions:
1. will it damage anything or effect characteristics by driving the car with this AAC unplugged?
2. is this 2 wire AAC component replaceable, or must one replace entire IACV assembly?
appreciate any help
Edited by JC71
The "2 wire AAC component" is just a solenoid, that opens and closes the idle control valve. It's PWM controlled by the ECU. It is hard to see how you can have the symptoms that you describe without it being caused by the valve itself being dirty and so not moving smoothly. Yes, I understand the rest of your description.
Will it hurt to have it unplugged? No. You will not have idle control so idle speed will be able to fall below stall point if and when you put too much load on it (AC on, PS turned to one side, etc).
Is it replaceable? I dunno. I think if mine ever goes that bad I will just be doing the whole ECU. Good excuse to go e-throttle and sidestep the whole idle control bullshit circus anyway.
  • 3 weeks later...
I replaced the entire IACV assembly with new unit from Nissan, idle acts the exact same, starts and runs with idle rock solid at 900, as soon as I plug in the solenoid from the new IACV the idle races up to 1400, even with idle adjustment on side back of intake manifold maxed out for lowest idle still way too high around 1200.  Again if I unplug the IACV, turn idle screw to about half and it runs fine at around 900. thinking about just leaving it unplugged, do not ever plan to drive it when its cold, and always stored in climate control garage, just sucks to spend 500 dollars and have no change, could have left the original at this point. any other thoughts as to what it could be? maybe not even worth pursuing? that is if cold start idle aid was the only reason for Nissan to have this part anyway. tried AC and other loads and it never seemed to push idle below stall.
Yeah, that doesn't necessarily mean that it flows. If the exit side pipework is blocked somewhere (in the hose, in the nipple that it returns into the motor/plumbing, etc), but the supply side is not blocked, then when you crack the bleeder you will get flow from the open side. But when you close the bleeder - no flow. And.... therefore no heat.
You might have to work a little harder to prove it to yourself. When I bought my engine the entire IACV bleeder was choked with cooling system schmutz. I had to clean it and the pipework out before it would work.
You definitely have a big problem if with the adjustment screw closed up you're idling at 1200 rpm. Have you verified you have no vacuum leaks? No throttle shaft seal leaks? Nobody has messed with the throttle body set screws? I would love to see what Consult reports when your engine is idling that high.
I recall you're going to launch the OEM ECU into the bin in another post, unpopular opinion but throw the AAC, IACV, cable throttle & pedal all into the bin and convert to DBW e-throttle & pedal.
For quick install (minimum fab work) these guys have a great bit of kit:
https://outsidergarage.com/products/nissan-rb25-oem-dbw-conversion-kit
Hit up @outsidergarage for more details.
(I'm not affiliated nor do I use them)
Sure, but personally I'm a big fan of when you have a problem, don't make it harder to diagnose by changing more variables all at once.
That's perhaps not even correct in this instance though. If the OP were in fact to bin all that troublesome crap and convert to DBW, and then if the problem persisted, we would at least know that it was not caused by any of that troublesome crap and he could go looking for it in more likely places. AND... he would have a significant upgrade in niceness to go along with it!
  • Like 1
Sure, but you could just pull enough timing out of the map to make it idle at whatever RPM you want. Or close the throttle until it's about to bind to compensate for vacuum leaks.That's kind of why I'm not a fan of this approach, especially if OP isn't experienced at tuning these things.
I couldn't get this to work right, New clean IACV, coolant seems to flow and solenoid functions, but again as soon as I plug it in the idle raises, I ran the car for a good 1/2 hour messing around with various things it, no vac leaks.
At one point with the IACV plugged in I was able with the adjustment in the side of IACV turned all the way in get it idle down a little to around 1000, but no lower, and it would surge, I unplugged the IACV engine rpms drop to about 350, turned the adjustment about 3 turns in , set idle to around 800 rpms' and it idles smooth.
I set the idle stop screw abut the same so it cant drop below under load. the engine starts, restarts, with no load or with a load seems to run fine. I will have to leave it like this for now as I cant get it to function correctly with the IACV plugged in.
One other thing I discovered that might be the reason for some of the issues, the engine in the car is a RB25det neo from a Stagea along with the Stagea ECU. so alot of wiring, plumbing etc that is typically there in a R34 is not.
Spray carby cleaner around all gaskets and other possible vac leak locations on the inlet manifold. See if the revs change somewhere. If so, vac leak found.
Plug in Consult and see what the ECU says it is doing to the IACV. It will tell you how many "steps" it is commanding it to open. If it is not commanding it to open more than normal, then the problem is elsewhere. If the ECU is trying to drive the IACV really far open, then you know that it is either ECU cray cray or some input to it telling ti be stupid.
can you check if this is an auto ECU?
    • Hi, does anyone know how I can, or can a moderator remove this advertisement please.  Has been sold a long time ago and would like to remove references. Thanks.
    • There are adaptors that allow you to delete the booster and use an s15 clutch master cylinder.    if you want to keep the booster they are still available brand new
    • I visited again today: It would appear they have painted the main body of the car and some parts of some of the panels, so I can say that I now have BMW parts in my car, much to the envy of @Dose Pipe Sutututu It is still covered in dust which is quite the tease but I did look at a few circumspect spots that will be behind bumpers and such and wiped some dust away: After my repeated begging to PLEASE DONT PAINT OVER THE ENGINEERING CERTIFICATE (you have to re-engineer the entire car if they do) I see THIS: Which is great. Excellent job tbh at least to me. A better non dusty example would be the backs of the doors that have been painted: Giving a reasonable contrast between old and new (I know the old isn't clear coated on the inside of doors). The door card will well and truly cover where the old paint is, you can see in the second pic some of the black butyl/whatever shit is sticking the plastic sheet behind the door transfer that has happened since it's clearly been stuck back on. The most maddening thing about this colour is every time I saw it in the wild it looks like another colour, same with photos of many cars with the same colour looking wildly different in every photo anybody ever takes and this is no exception. But stand a little further back and it suddenly looks dark AF. I did tell them when I was discussing which of the 70 million charcoal colours to choose from (a porsche one, a BMW one, or a R32 GTR one etc) that if they just ignored me and chose one at random I would probably never notice. Maybe they did. But the colour is supposed to be B39 (BMW Mineral Gray). Boring I know, but the R34 sedan (to me) really shows off it's boat-ness when you paint it in a bright colour like bayside blue or white or whatever else. I do have a fondness for AR2 Nissan Red, but decided against that because it'll have pretty odd contrast to random bits unpainted (like engine bay, bits of trim etc, and maybe it'll fade). And people will always fkin comment on AR2. Everything remains super dusty. I have tracking numbers for the new heads, as well as some Improved Racing goodies, but they probably will be a next year thing by the time they end up on the car. I did some maths on the heads and I know why nobody goes to this extent in Australia, because it's really not worth it, given I could have just CNC'ed my current heads, bought a FAST102/TB and used my current rocker/spring/cam combination and get a 383 stroker (or stroked a 6.0 GenIV bottom end to 6.6L) built for the same price of just the setup in the mail/on the floor here. Or I could have bought a LS3 and a Drysump system. And then have a complete engine to sell. Oh well
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
