The stock one will outperform any aftermarket standard position exhaust manifold.
If you don't believe me, do a back to back test (same turbo, same boost, same timing) and you'll be super surprised.
That's good to hear I'll stick with the stock I hear they are good for 500hp and I'm only shooting for 350-400 once I can get this thing sorted and get to actually building it.
You'd need to weld on an external gate to achieve that number though. I can't remember seeing anyone make 500hp at the wheels with the stock manifold / internally gated turbo.
On 4/24/2024 at 2:40 PM, Chris_Guthrie said:
Well considering I have the exact same problem with that as the original one I don't think that the ignitor is the problem. I would imagine that this being such an uncommon problem the possibility of getting a new ignitor that is bad in the same way as the old one has to be very slim. I'll definitely pull everything apart this weekend and check the turbo out. Got quite a bit of things to check out Saturday like fuel pressure and the pcv so I'll report back once I do that.
Thanks everyone for all the replies this is all really helpful
Easiest way to know is to break out the multimeter and measure it when cold, then measure all the resistances again once it gets hot enough to misfire. Both the original ignitor and the J Replace version. Factory service manual will have the spec for the terminal measurements.
Edited by joshuaho96
Latest update, reinstalled the evap canister. No change. Disconnected the fpr vacuum hose, no change.
Hooked up the fuel pressure tester. 42psi when primed, consistent with what I've been seeing online. When running, drops to 34psi. Ideas on this?
Also, when I did my fuel pump rewire, I tested hot before tapping. I attempted at first to just unplug my relay to relieve fuel pressure and the pump still primed and ran. Thought that was strange. Unplugged the connector in the trunk by the fuel hat and was able to relieve fuel pressure that way. Starting to wonder if I jacked something up with my wiring because shouldn't be priming without the relay hooked up.
Just got back from a quick test and I'm really thinking that maybe the fuel line is sucking air in. I noticed when I removed the fuel pressure tester the hose on the fuel filter was easily spin-able. When it was twisting I noticed a slight change in the engine rhythm. Took it out to see and did fine again without boost and for the most part did fine in boost until I got a big hiccup about half throttle going up a hill. Going to investigate that further when I get more time. Probably just replace the fuel filter and the hose and see if there is any changes. Was able to go about 10m away today with the car feeling fine, actually felt a little stronger im guessing thats the splitfire coils (still an intermittent  misfire at idle).
18 minutes ago, GTSBoy said:
Is correct. Manifold vacuum at idle is about the difference
That's good to know at least. Guess I can rule out the pump. Also thinking could be bad fuel though I filled up my bike (11' R1) at the same place  the other day with the same 93 octane and got a crazy misfire that I never had on that before too.
If your working theory is that air is getting into the fuel hose and those air bubbles are causing lean-outs it would run horribly at first or most likely no-start until the air is purged.
Also, if your fuel hose isn't sealing too well more likely it will manifest as a fuel leak, not air leaking into the system. I would be suspect of the gas station potentially having dirt intrusion in their underground tanks if you think it's the fuel filter causing a fuel pressure drop that causes lean-out. Fuel pressure has to be measured under load or you have to take a delta measurement at different points in the circuit if the idea of getting the car to a dyno or running a hose all the way from under the hood into the cabin and having one person check fuel pressure while the other drives is unpleasant.
I'm thinking this but when I checked the fuel tank the fuel strainer under the pump was as clean as new. I do have a new fuel filter I'm going to replace that hose and filter just to be safe because maybe something did get through the strainer but I'm also going to attempt at some point next weekend to get the remaining fuel out and fill it up with some high quality fuel.
You need the fuel pressure gauge reading when the car is running and on boost.
Revving it stationary doesn't tell you much.
Get a wideband O2 installed, or borrow a portable one.
Will show very valuable data.
  • Like 1
Both of those things are on my to do but not quite in a position to do that just yet until I can at least get it running back to stock. Going to work on getting the exhaust manifold gasket and studs replaced first, an obvious need it now. Then I'll try out the new maf and see hownthat does. After that I'm thinking cas if I'm still having the same issues. Still need to run the fuel out and refuel I'll change the fuel filter tomorrow along with cleaning the iacv with carb cleaner. If all else fails I'm going to get a serial port and see if I can get some sort of data on what the ecu is seeing when the issue is happening but really hoping one of the methods above work out first. After I get a good base I'm going link but have to save for that so it'll be a while for that based on my tuners suggestions. Definitely need the exhaust leak fixed first though car has always fallen flat after about 4-4500 rpm since I've had it and suspecting that's the issue. Then I can move forward with the rest.
Have you explored this possibility further? I've been quietly watching this story unfold, early on I thought seems like bad fuel.
I got another MAF and installed it. Idle misfire was still present. Finally got the tank low enough to refuel and did so. Did a short drive to warm the car up and no issues, pretty short drive. Going to attempt soon to take a longer drive to see. I don't think the MAF fixed it if anything, definitely thinking it was fuel related. As soon as I put fresh fuel in the car felt so much better. But, still need a longer test drive to verify. I'll report back once done.
I'm definitely going to be getting monitoring and tuning parts soon as my next upgrade (decided on the link after talking with my tuner), just been real tight with just purchasing the car and sudden onset of issues. I've also ordered a new exhaust stud kit and gasket to fix that obvious problem. Once it's back up to par I'll start with the goodies
  • 4 weeks later...
Issue resolved.
So I was driving a couple weeks ago and noticed everytime I got on or off the highway (long right hand turns) the car would bog for a second and then pick back up. Decided then to just change the fuel pump.
In doing so when I pulled out the fuel pump I noticed that the fuel strainer was very dirty on the bottom. Additionally, there was a little rust in the tank. The fuel strainer was only partially seated on the bottom of the pump which I was surprised to see was an AEM 340. I removed the fuel filter and it was clean coming out the out end and straight rust water coming out of the feed side.
I changed the fuel filter and replaced the fuel pump. While I was there I went ahead and installed radium studs in the fuel hat and rewired the fuel pump with the relay mod, correctly this time. Used 12ga straight from the battery with a 20amp relay and inline fuse.
Car feels much better. Only thing I have left to get it up to par is replacing the exhaust gasket and installing new exhaust mani studs to fix the missing one and the broken one. Once I do that I'll be investing in some data logging equipment. Looking forward to enjoying this 32 this summer. Wanted to thank all of you guys for all of your help and post the fix in case anyone is dealing with a similar issue.
  • Like 2
Just on this, as there's a huge issue in your assumption Dose.
The logic you've given, is the same logic old school NA guys give for "needing back pressure" in an exhaust.
If you free up an exhaust system, and keep injecting the same fuel in etc, at the same timing, you'll typically drop power.
Freeing the exhaust will often make an engine want a little bit more timing, and even sometimes a little more fuel, but then it'll make even more power.
There's many mods people do and "get no extra power" when running a comparison on the same tune.
Imagine a car tuned for 91, but now we say put 98 in it, see no difference. But as we now have 98 fuel, you can run more timing, and make more power, as the 91 was knock limited.
So just be very wary in your claim of "don't retune it and do a back to back and you'll see". The correct approach would be tune the car with stock manifold, swap the manifold to aftermarket, and retune it again. But no one wants to do that, and all the results we get are "this was stock, and this is manifold changed and tuned" and people put it all down as just the tune doing it.
My point is more so focused on the division between cylinders 1 to 3 vs 4 to 6.
Any low mount "bolt on" aftermarket manifold utilises an open T3 collector which has crap all scavenging effects.
Sure it might allow you to slap in more timing up top to make a little more but you'll lose all the down low performance.
Even Tao from @hyper-gear has experienced the same when modifying the stock manifold. He has experienced added lag by cutting out the divider inside vs. leaving it alone.
Twin scroll works, even if the effort is focused primarily on the manifold and an open scroll turbine housing.
Please don't confuse me with a V8 NA or Americans that thinks you need back pressure in a 4 stroke motor.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
