  On 14/06/2024 at 8:36 AM, Dose Pipe Sutututu said:
My point is more so focused on the division between cylinders 1 to 3 vs 4 to 6.
Any low mount "bolt on" aftermarket manifold utilises an open T3 collector which has crap all scavenging effects.
Sure it might allow you to slap in more timing up top to make a little more but you'll lose all the down low performance.
Even Tao from @hyper-gear has experienced the same when modifying the stock manifold. He has experienced added lag by cutting out the divider inside vs. leaving it alone.
Twin scroll works, even if the effort is focused primarily on the manifold and an open scroll turbine housing.
Please don't confuse me with a V8 NA or Americans that thinks you need back pressure in a 4 stroke motor.
Expand
Your claim of "same turbo, same boost, same timing" is why I commented on it. You can't change how the exhaust flows, not alter the ignition or fuel map, and instantly say one is worse than the other, as one is likely now out of tune to the other.
While turbo lag isnt great, it's also not the whole picture. Nor would I say the factory manifold is the best for fluid dynamics. That and most GOOD aftermarket manifolds additionally aren't aimed at stock/small sized turbos, nor do most of the companies building them have a Great idea on fluid dynamics, they just understand and build to the same basic principles. Those aftermarket manufacturers also don't have epically huge budgets to go doing shit tonnes of R&D to get the best performing manifold.
I'm not going to argue with you.
OP just wanted to replaced his stock manifold with another one for his stock turbo.
Besides wasting money, he will achieve nothing besides added lag and most likely 0 additional power.
Maybe of interest,
a little while ago I spoke to one of the guys from Rajab Racing Developments and he hinted to me they could be developing a new cast exhaust manifold. Incidentally, they have already made one for the barra and it looks functional
Expand
Ha ha, sorry dose, I wasn't meaning to argue the point on "it'll do f**k all". I was only shining a bit of a light in the flawed logic you used with it mate. :)
I 100% agree that there is zero point changing stock manifold with a stock turbo, unless the manifold is f**ked. And only reason I'd ponder aftermarket manifold on a stock turbo would be that I'm too scared too look at the potential ludicrous prices people are asking for a stock manifold! Ha ha ha
  • Like 1
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
