2 hours ago, Dose Pipe Sutututu said:
My point is more so focused on the division between cylinders 1 to 3 vs 4 to 6.
Any low mount "bolt on" aftermarket manifold utilises an open T3 collector which has crap all scavenging effects.
Sure it might allow you to slap in more timing up top to make a little more but you'll lose all the down low performance.
Even Tao from @hyper-gear has experienced the same when modifying the stock manifold. He has experienced added lag by cutting out the divider inside vs. leaving it alone.
Twin scroll works, even if the effort is focused primarily on the manifold and an open scroll turbine housing.
Please don't confuse me with a V8 NA or Americans that thinks you need back pressure in a 4 stroke motor.
Your claim of "same turbo, same boost, same timing" is why I commented on it. You can't change how the exhaust flows, not alter the ignition or fuel map, and instantly say one is worse than the other, as one is likely now out of tune to the other.
While turbo lag isnt great, it's also not the whole picture. Nor would I say the factory manifold is the best for fluid dynamics. That and most GOOD aftermarket manifolds additionally aren't aimed at stock/small sized turbos, nor do most of the companies building them have a Great idea on fluid dynamics, they just understand and build to the same basic principles. Those aftermarket manufacturers also don't have epically huge budgets to go doing shit tonnes of R&D to get the best performing manifold.
I'm not going to argue with you.
OP just wanted to replaced his stock manifold with another one for his stock turbo.
Besides wasting money, he will achieve nothing besides added lag and most likely 0 additional power.
Maybe of interest,
a little while ago I spoke to one of the guys from Rajab Racing Developments and he hinted to me they could be developing a new cast exhaust manifold. Incidentally, they have already made one for the barra and it looks functional
Ha ha, sorry dose, I wasn't meaning to argue the point on "it'll do f**k all". I was only shining a bit of a light in the flawed logic you used with it mate. :)
I 100% agree that there is zero point changing stock manifold with a stock turbo, unless the manifold is f**ked. And only reason I'd ponder aftermarket manifold on a stock turbo would be that I'm too scared too look at the potential ludicrous prices people are asking for a stock manifold! Ha ha ha
  • Like 1
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 馃槂
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
