Been a busy few months. Thought I'd provide a quick update.
Work done since last as of today:
  • Coilovers all round - adjusted by Tyre Worx in Hoppers Crossing
  • New rims and tyres, staggered 18x9 front, 18x10 rear (te37 reps) by Tyre Worx in Hoppers Crossing. Really wanted a good fit without touching bodywork. Can't believe how much of a difference this made to both looks and driving.
  • Wheel alignment
  • Rust treatment in boot and boot edges, followed by spraying and sealing
  • Resealed taillights (though I stuffed it up and need to redo it as water is still coming in, tips appreciated)
  • New spark plugs
  • Replace all filters
  • 2x oil changes, with a flush between
  • Fuel flush
  • Degreased and washed engine bay out
Pretty happy where it's at (for now). I'm not a horsepower chaser here, really just want to keep it clean and restored to its factory glory.
If anyone has tips on stuff worth doing, keeping it in line with the vision above happy to hear it. Was wondering if it was worth replacing things like coil packs and factory hoses or do you wait until they break?
More from a maintenance restoration point of view.
Anyway, cheers!
Photos to help those with a Black R33 GTS-T:
Edited by sycotix
  • Like 2
Nice man glad it all somewhat worked out in the end. Any update on the inspection company?
As for coil packs stay away from red and yellow ones. Black (oem) or blue splitfires, or upgrade the whole lot to 35 GTRs/other new ones.
  • Thanks 1
Thanks mate appreciate the tips! I lodged the matter with VCAT in the end so that will take a while to actually pop back up but not letting them get away with it.
  • Like 2
  • Wheel alignment
  • New spark plugs
  • Fuel flush
Anyway, cheers!
Hey @sycotixwhere did you get the spark plugs replaced?
was that somewhere in Hoppers crossing too?
I’m planning to go to Backlash Automotive in Hoppers when my clovers come but if you found a decent garage on this side to do spark plugs, I’d be interested too.
PS: also been reading the drama with the car at the start. Glad you got that sorted
Hey mate, I'm sure Moe over at Tyre Worx and Garage Worx in Hoppers will do that but I did my spark plugs myself when I gave it a full service after buying for peace of mind.
Thanks for the feedback!
    • Hi all. So I have my GTR on the lift and have been working on it a few days and today I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
