Hello everyone ,
I am currently building a 3.2 L with an RB26 cylinder head my block is stock and I will run E85 and E100
My mapper who is Romain Levesque from dear RaceCAL LtD (former syvecs technical director) asks me to make a ratio of around 9.5.
so after reading a lot of topics on it
I found pistons with a CR 9.0 and 10.0 expensive IRP
what direction would be taken to achieve a ratio of 9.5 without having to plane the block by 2mm or to do it a minimum, but to be able to play with the thickness of the cylinder head gaskets
thank you in advance for your response
  On 17/04/2024 at 11:00 AM, krysto_77 said:
t of topics on it
thank you
Expand
I'd verify how invested in exactly 9.5 he is if it turns out to be a massive amount more effort to go 9.5 vs 9.0 or 10.0.  He may have just said that as a suggestion not realising it'll be a huge deal to go specifically there when half a point either side isn't so bad.
  • Thanks 1
  On 17/04/2024 at 11:50 PM, Lithium said:
Je vérifierais à quel point il est investi exactement dans 9,5 s'il s'avère que cela demande beaucoup plus d'efforts pour passer à 9,5 contre 9,0 ou 10,0. Il vient peut-être de dire cela à titre de suggestion, sans se rendre compte que ce serait une grosse affaire d'y aller spécifiquement alors qu'un demi-point de chaque côté n'est pas si mal.
Expand
yes you are right, indeed it is for information only.  there is not much difference being at 9 or 9.5 or 10.  but when I see that you have to plane the block by 2mm if you have taken (example) CP piston which means that you end up with an 8.2 with the rb26 cylinder head.  hence the question I ask is what would be best to achieve what he is asking me.  take pistons in 9.0 or 10.0 to avoid planing a famous 2mm on the block knowing that I worked on the dome of the cylinder head which became total hemispherical17134181700198466972571900996895.thumb.jpg.d9873563c434a92f3d37240bdf5fcf7d.jpg
Expand
Which is a thing done by no-one ever. Not even remotely a good idea.
I would run an engine with 10:1 these days. Good management and fuel compared to the early 90s when these boat motors were designed & built.
  • Like 1
Expand
You will need custom pistons made, the combustion chamber is to modified for any off the shelf piston to give a good compression ratio
  • Like 1
It's also worth noting that the static compression ratio needs to be considered in conjunction with your camshaft specification to ascertain the dynamic compression. 9.5:1 is fine with stock cams but if you're running 288's then you'll be pumping 120psi and it'll be a dog.
  On 21/04/2024 at 11:16 PM, Komdotkom said:
Il convient également de noter que le taux de compression statique doit être pris en compte en conjonction avec les spécifications de votre arbre à cames pour déterminer la compression dynamique. 9,5 : 1 convient aux caméras d'origine, mais si vous utilisez des 288, vous pomperez 120 psi et ce sera un chien.
Expand
I see what you mean !! 👍
so I drive with E85 AND E100 my cylinder head and full supertech with 270° camshaft and 10.25 lift
this weekend I spoke with my mapper and he told me 10 ratio would be even better
so I went to set up a setup with :
3.2l crankshaft from expensive spool import with a stroke of 91mm
Nitto or IRP connecting rods length 152.5 mm
and piston irp ratio of 10
after having the information near spool import the setup did not work because of the crankshaft which is 91 mm
therefore the assembly mounted in the engine block will come out 1mm high above the cylinder head gasket surface
so I have to review the construction of the lower engine
low IRP is Italian I am French I wanted to limit the costs because as they are in Europe I do not have customs fees to pay 🤷‍♀️
  On 22/04/2024 at 9:36 PM, Komdotkom said:
Vous pouvez probablement simplement acheter la manivelle, les bielles et les pistons auprès de Spool Imports sous forme de package.
Expand
Yes indeed ; They offered it to me, I'm waiting for their quote 😉
