Hello again, I have a 1991 r32 gtr that I’ve modified and dynod. The power it gave me was a bit disappointing with 533 wheel horsepower and 444nm torque on a dyno jet dyno. On a heavier dyno it would read to about 433 wheel horsepower. I say disappointing because it currently has :
CP oversized 87mm pistons
Eagle H beam rods
Extended crank with the nitto collar
stock oil pump (nitto on the way)
stock sump (leask sump on the way)
Garret G35-900 single turbo
^ With 26psi of boost (1.6 bar)
6boost v band manifold
turbosmart 60mm external wastegate
Brian crower 264 cams
tomei gaskets all around
arp head studs
dual wallbro fuel pumps
dw 1050cc injectors
greddy radiator
metal Intercooler pipes
nismo thermostat
offbrand fuel regulator (tomei regulator on the way)
ngk 7’s spark plugs (tuner refused to tune with 8’s for my car)
Running on a motec m800
I know that running on e85 and opening the rpm to around 8500 instead of my current 7200 will also boost my power yet will it increase a lot or just slight because people like cardoGTR and andrew Hawkin from motive were all running around 600 wheel horsepower on the same setup as mine. Any feedback on what I’m missing?
thanks
https://www.sau.com.au/forums/topic/485443-rb26-expected-power/
I'd say post the dyno sheet so people can look on it, but you already know all dynos are different.
I mean 26psi on Petrol/Gasoline seems pretty up there, and if you aren't revving it out then unless your torque is really nosing over, then of course more RPM will equal more HP.
If you think E85 will make the difference between 533whp and 600whp the answer is absolutely yes. Given the only thing that makes power is the turbo, and you've got plenty of boost in there, it all seems semi reasonable to me. Curious to see what other people say though.
The one thing that never lies is MPH at the drag strip. See what you trap. (ok, it can lie a bit with altitude and conditions etc)
  • Like 2
Any chance you know how much timing your running to make that power?
Did your tuner say what the limitation was when they were tuning (eg knock? boost control issues? etc)
And final thought, if you are able to easily source e85 where you live, I'd 100% recommend using it. But before you go back for the flex tune, you probably want to get some bigger injectors. On e85 I see you maxing out those 1050cc injectors real quick.
  • Like 2
As already mentioned, we need to know what was limiting you. Fuel? Knock? If I understood correctly, you have your rev limiter at 7200rpm?  If so, that is very low/strange, and your tuner would have made a point to discuss it. A G35-900 will continue to make power north of that.
What gas and where are you located?
Edited by TurboTapin
  • Like 2
I don't understand how a heavier dyno will make less power, but anyhow let's take your first figure. You're making 397kW on normal 98RON.
That's a pretty decent number, considering you'll be pretty knock limited with your fuel choice.
Throw in E85, more timing, more RPM and you'll go over 500kW with ease
  • Like 1
  • Thanks 1
2 minutes ago, GTSBoy said:
I expect it's just slang from somewhere for a low reading dyno.
Probably originates in the US where the inertia dyno is king and some actually might be "heavier" than others.
what a load of street takeover baloney, of course it's some US jargon or bs.
what exhaust, intercooler, turbine housing?
I don't get this part ngk 7’s spark plugs (tuner refused to tune with 8’s for my car) why is the keyboard operator telling you what parts go in your car comes of as controlling, controls your engine, your tune, your horsepower.
  • Like 1
He limited my rpm because of some ptsd he had from a previous rb26 getting head starvation, and I’m located in Dubai using pump gas. We made more power running a bit more lean but for some reason my car did not like being that lean
Stock intercooler and 0.83 housing, everybody I know with a gtr and running north of 20 psi has 8’s for plugs and for some reason my tuner refused to tune my car if I went to 8’s and said he’s not responsible for any damages that’ll happen. That freaked me out a bit and made me stay on my 7’s.
yeah your correct i meant it as a low reading dyno and not a “heavy dyno” that’s just the slang people said to me so I repeated it here
My tuner said my timing is 12 on one bar of boost.
I like the drag idea, and unfortunately I didn’t take a picture of the dyno sheet. I’ll try out my luck on the drag and see what I clock
Rb's have issues with bottom end starvation, not head starvation. Which either way, you probably wouldn't ever see on a dyno. Strange...
What's pump gas for you? Octane rating?
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
