Now as I understand it the engine numbers are sequential for the rb26.
EG stamped - RB26040100A is a 40,100 engine.
Now they made between 1988 and 1994 43,834 R32 GTR's
In 1994 they made 7,464 r32 gtr's.
So if you have a ~37,000++ number RB26 it's "safe" ish to assume its an 1994 motor and a long nose crank ?
The long nose crank being introduced somewhere in Feb of 1993.
https://www.sau.com.au/forums/topic/485447-rb26-build-year-check-my-math/
found this on the forum , suggests I am in the range
From the segmented (potentially incorrect) information I've found that;
Early R32: RB26000XXXX to RB26002XXXX
Mid R32: RB26003XXXX (V-Spec I RB26-03XXXXX - Reference Classic Register)
Late R32: RB26004XXXX (V-Spec II RB26-042XXXX - RB26-045XXXX - Reference Classic Register)
Early R33: RB26005XXXX
Mid R33: RB26006XXXX (as per the engine in this R32 V-Spec II, which is what I'm concerned about from legitimacy perspective)
Late R33:  RB26007XXXX
Early R34 (2000+):  RB26008XXXX
  • Thanks 1
I think you pretty much nailed it.
  • Like 1
THANKS !
Sequential at times but overall Incremental is probably a better way to state it.
Chassis numbers with Nissan's are like that too, jump when a change of some kind occurs.
Bit of a surprise to find out that despite being a 32 RB26, it's most likely the better crank.
Winner Winner.
11 minutes ago, Predator1 said:
Doesn't really do any good, especially without billet gears. The oem pump is crap. If it doesn't break, the screws holding the backing plate will come loose.
I think he's just happy that the crank doesn't have to come out of the engine in order to have a good (read reliable) oil pump.
  • Like 1
Over the moon in fact.  Engine is coming out to put on a new enlarged sump. I planned on putting on either a new pump(Tomei / Nitto) or billet gears.   But a bit of waste of time if the crank has narrow collar.
Things spiral quickly, if crank is out, new bearings ... maybe new rods and pistons ... wait just rebuild the engine... oh but I should get an N1 block  .... 40k later  .... haha.
I've never seen this on a factory built RB26 have the screws come out, or gears break for that fact. Only once someone has touched the motor have I heard / seen it.   I've seen a few factory built Rb25's shatter gears but we talking high mileage extreme beating at drift track, constant limiter for a full season.  Well outside what it was built for.
Def happens. Happened to mine too. Have pics to prove. Super picky, I noticed the OP slowly dropping.
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
