Hello,
Has anyone experienced their signal light being constantly on when parking or headlights are on?
I'm putting my car back together after painting. I didn't pull out the hole chassis harness.
I hooked up the chassis harness in the bay along with semi-installing a new ecu harness.
I put power to the car today to play some musicand check on thing while I worked.
I noticed when I put on the parking lights that the left rear signal was constantly on. I thought for whatever reason. All the signal light needed to be install. The rear left signal did turn off after all the other signal bulbs where installed, but now the other 4 are lit. The left 2 are brighter than the right. I noticed that if u pull out the front left bulb them the left rear turns back on.
Strange.
Hazards work fine. Activating the signal from the stalk works. I unplugged the signal stalk power to see if that may have been the issue. Removed the fuse for the signals and they stay on constant but not blink.
I have LED 194/T10 bulbs. They're not switchback.
Things worked as normal before I took thing apart and painted. The only new things I wired were two removed leads to my fuel pump relays.
Could it be the stalks? I bumped them plenty while working. Just from today I assessed them good and no flickering from contact on so it's hard to say it's the stalks.
The issue somewhere in the chassis harness?
Did some more messing around with this issue.
I think the stalk is the problem. i wiggled it around a bit. When i went to put the signal up for a left turn, all the signals blinked lol.
I'm gonna try and clean the tarnish off the copper and see if that works.
this still doesnt explain why the left side/fronts are constant on ACC/On after i pulled the stalk. may be a ground from the stalk thats causing it.
IDKkKkKk. I'll report back
Are you sure you can use LEDs in the indicator lamps? On a car that old? It doesn't work on many old cars because the indicator relay can't cope with the wrong impedance out at the lamp positions and the LEDs will happily light up even with minimal current flowing through the indicator relay.
And when I say "indicator relay" I mean the flasher, not a relay relay.
Beyond that, I would say that you have caused yourself a wiring fault and that you would be well advised to work through the wiring diagram and the actual loom with a multimeter.
  • Like 2
Expand
I've had these LEDs and a LED EP34 flasher relay in the car since 2020.
No fuses were popped either.
I'll multimeter and clean off the tarnish tomorrow. From how the lights were acting after I diddle the stick make me lean towards a stalk problem.
Expand
That would be a rarity.
You can emulate the function of the stalk just by bridging the appropriate pins in the connector. If you can make it function correctly by doing so, then the wiring etc is OK and it is the stalk.
  • Like 1
SOLVED
simple solution.
After wrecking by brain, i ended up jist giggling everything i could.
At one point last week I noticed that the left side signals shut off for a split second. I wasn't sure what triggered it.
I spent time cleaning up wiring, re-wrapping and adding DT connectors to my IC7 stuff.
I bought a new hazard and stalk hoping that would work. The stalk did fix some function issue but not the steady on. Hazard didn't fix it.
I started just tracing everything. Once I got to the engine bay I notice my engine harness was droopy. I started moving it and the signals flickered. Come to find out that the starter + turned off sigmals when it grounded out on a bolt
I have a Wiring Specialties pro harness so I'm not sure if this is specific to it.
So it should work proper once I hook everything up
Edited by SLVRBAKSLPZ
  On 12/05/2024 at 12:50 AM, GTSBoy said:
That is a dead f**king short of B+ to ground. Scary.
Expand
Yeah I'm terrible with understanding wiring. Outside of being given install instructions, I have a hard time deciphering diagrams and terminology.
I have the wiring manual and its all hieroglyphs lol
    • Don't they cool down technically when you're sitting at a set of lights?
    • The circuit if not a resistor divider is using an opamp to deliver a specific current normally. By maintaining the current as resistance changes, the voltage does too. Add to that, thermistors are normally non linear too,which can make creating a function impossible. Most uses of a thermistor people will utilise a lookup table to get the corresponding temperature.
    • On a scale of 1 to 10, how shit are the RE003's? (10 being ultra mega shit) Was hoping they'd be alright for a non-daily driven R32 that might get driven to Charnwood Macca's in the dry once a month, and maybe the odd hoon up and down the hills that pass for mountains in sunny Canberra.  Bob Jane currently running a "Buy 4 Get 1 Free" deal on RE003s and my brain can't comprehend anything else being value for money
    • Yeah, they look good. I should try to fit them on mine. But being a GTSt, the guard shape probably doesn't suit properly.
    • Nah, it's not a simple voltage divider. I'm not enough of an electronics guru to know how they make these circuits work. If I had a better idea of how the ECU's temperature measuring is done, I could then actually do as you want, which is turn that resistance chart into a voltage chart. But my approach has not worked. What I did was interpolate the sensor ohms values for the temperatures you listed, as you did not have any of them on a temperature ending in zero or 5. These are: °C ECU V sensor ohms (interpolated) 58 2.68 11.85 57 2.7 11.89 56 2.74 11.93 54 2.8 12.01 49 3.06 12.208 47 3.18 12.284 43 3.37 12.42 I then assumed 5V supply to the resister and calculated the voltage drop across the sensor for each of those, which is just 5 - the above voltages, and then calculated the current that must be flowing through the sensor. So you get:             Values in sensor °C ECU V sensor ohms (interpolated) Supply volts Volt drop Current 58 2.68 11.85     5 2.32 0.195781 57 2.7 11.89     5 2.3 0.19344 56 2.74 11.93     5 2.26 0.189438 54 2.8 12.01     5 2.2 0.183181 49 3.06 12.208     5 1.94 0.158912 47 3.18 12.284     5 1.82 0.14816 43 3.37 12.42     5 1.63 0.13124 And then use that current and the ECU's sensed voltage (which must be the voltage drop across the in ECU resister is there is one) to calculate the resistance of that in ECU resistor. You get:             Values in sensor   Other resistor °C ECU V sensor ohms (interpolated) Supply volts Volt drop Current   Volt Drop Resistance 58 2.68 11.85     5 2.32 0.195781   2.68 13.68879 57 2.7 11.89     5 2.3 0.19344   2.7 13.95783 56 2.74 11.93     5 2.26 0.189438   2.74 14.46381 54 2.8 12.01     5 2.2 0.183181   2.8 15.28545 49 3.06 12.208     5 1.94 0.158912   3.06 19.25592 47 3.18 12.284     5 1.82 0.14816   3.18 21.46325 43 3.37 12.42     5 1.63 0.13124   3.37 25.67816 And that's where it falls apart, because the resulting resistance would need to be the same for all of those temperatures, and it is not. So clearly the physical model is not correct. Anyway, you or someone else can use that information to go forward if someone has a better physical model. I can also show you how to interpolate for temperatures between those in the resistance chart. It's not fun because you've got to either do it like I did it for every 5°C range separately, or check to see if the slope remains constant over a wide range, then you can just work up a single formula. I'm just showing how to do it for a single 5° span. For the 58°C temperature, resistance = 11.77+2*(11.97-11.77)/5 The calc is a little arse backwards because the resistance is NTC (negative temperature coefficient), so the slope is negative, but I'm lazy, so I just treated 58 as if it was 2 degrees away from 60, not 3 degrees away from 55, and so on.
