Hello,
Has anyone experienced their signal light being constantly on when parking or headlights are on?
I'm putting my car back together after painting. I didn't pull out the hole chassis harness.
I hooked up the chassis harness in the bay along with semi-installing a new ecu harness.
I put power to the car today to play some musicand check on thing while I worked.
I noticed when I put on the parking lights that the left rear signal was constantly on. I thought for whatever reason. All the signal light needed to be install. The rear left signal did turn off after all the other signal bulbs where installed, but now the other 4 are lit. The left 2 are brighter than the right. I noticed that if u pull out the front left bulb them the left rear turns back on.
Strange.
Hazards work fine. Activating the signal from the stalk works. I unplugged the signal stalk power to see if that may have been the issue. Removed the fuse for the signals and they stay on constant but not blink.
I have LED 194/T10 bulbs. They're not switchback.
Things worked as normal before I took thing apart and painted. The only new things I wired were two removed leads to my fuel pump relays.
Could it be the stalks? I bumped them plenty while working. Just from today I assessed them good and no flickering from contact on so it's hard to say it's the stalks.
The issue somewhere in the chassis harness?
Did some more messing around with this issue.
I think the stalk is the problem. i wiggled it around a bit. When i went to put the signal up for a left turn, all the signals blinked lol.
I'm gonna try and clean the tarnish off the copper and see if that works.
this still doesnt explain why the left side/fronts are constant on ACC/On after i pulled the stalk. may be a ground from the stalk thats causing it.
IDKkKkKk. I'll report back
Are you sure you can use LEDs in the indicator lamps? On a car that old? It doesn't work on many old cars because the indicator relay can't cope with the wrong impedance out at the lamp positions and the LEDs will happily light up even with minimal current flowing through the indicator relay.
And when I say "indicator relay" I mean the flasher, not a relay relay.
Beyond that, I would say that you have caused yourself a wiring fault and that you would be well advised to work through the wiring diagram and the actual loom with a multimeter.
  • Like 2
I've had these LEDs and a LED EP34 flasher relay in the car since 2020.
No fuses were popped either.
I'll multimeter and clean off the tarnish tomorrow. From how the lights were acting after I diddle the stick make me lean towards a stalk problem.
That would be a rarity.
You can emulate the function of the stalk just by bridging the appropriate pins in the connector. If you can make it function correctly by doing so, then the wiring etc is OK and it is the stalk.
  • Like 1
SOLVED
simple solution.
After wrecking by brain, i ended up jist giggling everything i could.
At one point last week I noticed that the left side signals shut off for a split second. I wasn't sure what triggered it.
I spent time cleaning up wiring, re-wrapping and adding DT connectors to my IC7 stuff.
I bought a new hazard and stalk hoping that would work. The stalk did fix some function issue but not the steady on. Hazard didn't fix it.
I started just tracing everything. Once I got to the engine bay I notice my engine harness was droopy. I started moving it and the signals flickered. Come to find out that the starter + turned off sigmals when it grounded out on a bolt
I have a Wiring Specialties pro harness so I'm not sure if this is specific to it.
So it should work proper once I hook everything up
Edited by SLVRBAKSLPZ
On 5/11/2024 at 7:50 PM, GTSBoy said:
That is a dead f**king short of B+ to ground. Scary.
Yeah I'm terrible with understanding wiring. Outside of being given install instructions, I have a hard time deciphering diagrams and terminology.
I have the wiring manual and its all hieroglyphs lol
    • Ya thankfully I've been able to drive it, it's pretty fun however I noticed yesterday while driving to work that my left side of the car is very wobbly, like any bump I go over it jolts the whole vehicle and pulls the steering wheel, I kicked the wheel a few times once I got home and it's a very distinct metal on metal clunk, so I guess I need to take a look at my suspension, maybe it's a control arm bushing or tie rod
    • With Tyroola, they're probably 10 years old. It's already pretty clear that they've given the job of copywriting their adverts to an artificial stupidity (which could be a Year 9 dropout, or someone recently arrived to Oz with almost no English).
    • "Here's how it works: Buy a set of four Pirelli tyres." Hey I think these guys are on to something 馃ぃ
    • Absolutely! I've been in love with them since I was a kid. I remember doing a school essay on Humvee's back in grade 5 haha. I always wanted one, but didn't have the space nor the funds. With us now looking for another larger home with a larger garage, I'll have room to park it. They have also gone down considerably in price. The US army has been phasing out Humvee's, so they're flooding the market which also brings down H1 prices.  It shouldn't be a problem to drive around here, I live in the suburbs. I would absolutely not buy one if I lived in a city though. They are known to be terribly unreliable. People often swap out the original 6.2/6.5L for a more reliable Duramax.  H1 and Humvee's are identical, minus the fact that the H1 has a dash and seats. It sadly also makes the H1 more expensive. I've driven both and the Humvee interior, or lack thereof makes it extremely loud and unpleasant to drive. Don't get me wrong, the H1's interior is horrendous, but at least it's present. Most do a custom interior in a Humvee which I'm also more than happy to purchase.
    • Then I realised it was just a typo. I was hoping for a set of Pirellys for my 5 series.
