Hi guys, I have a ECR33 97 model. Engine has a cracked ring land. Would it better to rebuild the series 2, or buy a second hand AWD 25det Neo from Japan from ~$3500 tidy it up a bit with new seals and so forth and use that?
I'm leaning more towards the NEO option but understandably they're very old engines too now, so could be just buying problems. Cheers.
https://www.sau.com.au/forums/topic/485492-rebuild-vs-second-hand-neo/
An excellent question. Both answers are correct.
I think the reality is that any Neo you get from Japan may well be the same as any other engine that has spent too many years in Japan. That being the problem of low to zero maintenance and oil changes, etc etc. So any Neo you get from Japan should be considered to be sufficiently risky to warrant planning to pull it apart and rebuild it anyway. That's a significant extra $3.5k impost on top of doing the same to your S2 engine, and the question has to be asked, would you rather have the (somewhat small) betterness of the Neo for $3.5k, or would you rather spend up to $3.5k on even better betternesses for the S2? New ECU? Better triggering? Better oil pump, sump, cam covers, etc?
I would avoid the AWD motor in a RWD using a modified RWD sump and pickup.
The way the pick up is positioned, you'll have oil pick up issues on hard acceleration on a track around bends.
Even with a baffled, gated sump.
I suppose if you don't race on a track and it's used for straight line activities or street use you might be ok.
  • Like 1
5 hours ago, admS15 said:
I vote for rebuilding current RB. At least you'll know exactly what condition your engine is in afterwards and no future unpleasant surprises.
Best option, at least it's not an engine lottery.
These NEO motors are close to 30 years old, they're doing ok.
  • Like 1
Yeah, better just to cut the diff off the awd sump and grind down the fins on the bottom.
  • Like 1
13 hours ago, niZmO_Man said:
Yep, back in the day when you could pick up a Stagea RB25 NEO for $1,500 it was worth it. These days... just chuck your V8 or B58 in.
If you're going to go v8 or really any swap now with all the tax, I'd most likely just get rid of the car and start with something else. Unfortunately, I have a mate with a surplus of ls and Ferrari/Maserati v8's that's always tempting me FFS lol.
  • Like 1
Or buy one someone built earlier! ;)
(realistically V8 mustangs or MKV supras are great).
I see people nowadays putting ZF8's into MK4's, and people putting 370z gearboxes, diffs, axles into R and S chassis and it's like.... just get a 370z at that point and mildly boost the 3.7 instead of the 2L and away we go...
My vote is rebuild s2 engine or maybe get a neo (but expect you may need to rebuild that too).
Doing an engine conversion you would have to be a true tragic nowadays and actively be aware there's better/smarter options for value.
10-15 years ago, the answer would always be buy a good import motor and so many machine shops make.a hash of an engine rebuild, or they think they are some sort of RB magicians and want 40k.
Now as others have stated, you are buying a VERY old used motor. So rebuild is the correct answer.
Just finding a machine shop that will both do a good job and charge you a regular price is now your challenge.
The complexities involved with getting a v8 swap done, and the sacrifices for clearance etc not worth it imo unless its a drift car or similar.
What if I told you it fit easier than the RB...... ;)
Realistically it's a lot of work, but suprisingly similar IF you didn't have a R33 with literally all of the supporting accessories and electronics and manifolds and cooling ready to go.
If you had literally a bare engine bay and no transmission, it'd be an apt comparison to make. If you just want to make 280-300kw all day just rebuild the RB and get a modern turbo and enjoy life.
Yeah I understand what you mean, but the LS swaps I've seen done to r33s (admittedly to drift cars). You have to hammer out the transmission tunnel to fit the t56/tr6060, cut and box the drifters side firewall for head clearance. All stuff that's not terrible, but don't want to do to my cleanish gtst.
I've decided to buy the NEO and rebuild it, maybe best of both options lol.
  • Confused 1
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
