Am wondering what the difference between the 2 is. My turbo seal has blown and an r34 turbo is one of the items in the cart. What would be the advantages of going for an r34 neo turbo as appose to another r33 series 1 turbo? I heard the r34 turbos have a plastic front wheel?? And ceramic exhaust wheel? Also heard the r34 turbo is bigger in size than a hiflow r33 turbo can anyone confirm this rumour? Any help on this matter would be great
https://www.sau.com.au/forums/topic/48550-r33-turbo-v-r34-neo-turbo/
If your car is a series 2 R33 then they are pretty much identical. The late R33 & R34 turbs both have a plastic (nylon or similar I believe) compressor wheel & a ceramic exhaust wheel, where as the R32 (lower flow) & early (series 1) R33 both have steel compressor wheels & ceramic exhaust wheels.
The plastic compressor on the later turbos was to aid spoolup due to the lower weight/inertia of the plastic compared to the steel.
All have will have the same problems with to much heat/boost ie they'll spit the ceramic exhaust wheel into the cat.
I have an R34 turbs on around 12psi & my biggest prob seems to be spark/mixtures
oh true, yea i had an idea about the plastic type front wheel minimising spool characteristics, but as for the size well was unsure, mine is a series 1 r33, so an r34 turbo maybe slighty larger but im thinking its not going to make a difference though.
oh ok, well regardless, the r34 turbo that im getting is coming in the package deal along with everything else, my turbo has blown an oil seal so it need replacing anyway, the engine is going to be run in for a fair while and not flogged so i can keep my licence so the turbo doesnt have to perform wonders anyhow. Just drive me from A to B. I dont want to lose my licence again
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
