Hey guys just wondering if I can get some clarification on this refrigerant pressure sensor wiring. I bought a 3 pin pigtail to wire in a refrigerant pressure sensor and I just want to make sure I'm reading the schematic and connecting it properly. My ECU doesn't have anything in pin 57 so I put a pin in and ran it to the WHITE wire on the pigtail. Then pin 48 to the BLUE wire and connected the GREEN wire to ground. After doing this I went for a drive and my CEL came on. The car also had jumpy acceleration. Since pin 48 is also the power source for the throttle position sensor I'm wondering if I messed up or reversed the wiring somehow. Any help is appreciated, thanks!
Well, what you've done looks correct, but only if the sensor has the same pinout as the stock sensor. If it's not a stock or stock equivalent, then there's some chance that you've got two or more of those switched, which could be anything from non-damaging to let-some-smoke-out.
  • Like 1
24 minutes ago, GTSBoy said:
It's not the connector I'm concerned about - it's the sensor itself. The connector is agnostic - doesn't care what you're doing with it. The pins on the sensor need to match what the ECU thinks it's pins connect to.
Right, sorryー I'm an idiot, of course it's the sensor not the connector 😳 So I just did some digging and found out the part number I was given by someone at Nissan is actually the wrong part number....so obviously it doesn't work properly and I probably fried something in the process.
With that diagram you posted first, often the adjacent section of the workshop manual will confirm what the wires actually do as well. Of the 2 wires between the sensor and ECU I assume 1 is power supply, probably 5v and the other is signal to the ECU, but it isn't possible to tell which is which from the diagram.
Unfortunately if you have grounded the ECU 5v output by accident you might have damaged the ECU (or if you are lucky just popped a fuse).
Why does the ECU not have these wires, was it a non-AC car or a different ECU to factory?
  • Like 1
It's an engine swapped car that I knew about when I imported it. What I didn't know is that whoever swapped the engine didn't swap the harness....so it's an RB25 with an RB20 harnessー a complete shit-show to say the least. For the most part everything runs fine (until I tried to hook up this sensor 🤦‍♀️) I feel like the ECU is fried due to the incorrect part number I was given but I'm able to get another one from a friend so once I order the correct refrigerant pressure sensor it should be ok....
  • Like 1
And double double triple double check the pins on the sensor, making sure you understand the orientation of the connector view on the diagram and hopefully the pinout on the sensor itself is documented on its paperwork, for comparison and triple double quadruple double checking.
  • Thanks 1
    • Interesting.  Great info. thank you.  Give a few days to get that name plate.  I have a busy life most weeks.  I will be in touch.
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
