EndZee Posted May 30, 2024 Share Posted May 30, 2024 Hello, is that speed sensor? Why doesn’t it have any cables/2pin but steel cable/rope? Photos of sensor R33 gtst auto I swapped it on manual with rp71c#2 gearbox prob rb20det r32. if I can’t connect current sensor is there any chance that ca/sr speed sensor or rb25automatic sensor will work plug n play? Link to comment https://www.sau.com.au/forums/topic/485535-rp71c2-speed-sensor-help-please/ Share on other sites More sharing options...
GTSBoy Posted May 30, 2024 Share Posted May 30, 2024 What you are holding that pic is a mechanical cable speedo drive. Not a speed sensor/sender. The R32 gearboxes use cable drive to the speed o head. No, you cannot put an auto tranny's speed sensor in a manual. I don't know of a solution for a speed sensor that will work with the R33 dash that will go into that box. The similar boxen from S chassis cars (SR20, etc) use electronic sensors, but I think the drive gears are wrong. The R32 turbo box will not hold up to the torque of an RB25DET for many years. You will wear out the input shaft bearing. You should probably plan to replace the box with an R33/4 box and then your speed sensor issues will be simpler. Link to comment https://www.sau.com.au/forums/topic/485535-rp71c2-speed-sensor-help-please/#findComment-7990096 Share on other sites More sharing options...
EndZee Posted May 30, 2024 Author Share Posted May 30, 2024 Thank you very much for answer! 🙏 One more question. My car is sitting waiting for turbo to be repaired. Is speed sensor somehow related to mileage? Will it add or count mileage without speed sensor plugged in? Link to comment https://www.sau.com.au/forums/topic/485535-rp71c2-speed-sensor-help-please/#findComment-7990097 Share on other sites More sharing options...
GTSBoy Posted May 31, 2024 Share Posted May 31, 2024 (edited) No speedo = no odometer Also, in case you think that that's a good thing (which it is if you want to keep the mileage artificially low), the ECU needs the speed signal to do things properly. The ECU makes different decisions about things like idle speed etc when it knows that you're moving. The HICAS and various other systems also need to know vehicle speed or they can chuck the sads too. Edited May 31, 2024 by GTSBoy Link to comment https://www.sau.com.au/forums/topic/485535-rp71c2-speed-sensor-help-please/#findComment-7990098 Share on other sites More sharing options...
WMDC35 Posted May 31, 2024 Share Posted May 31, 2024 R33 non turbo manual has the electronic speedo drive in the small box. Link to comment https://www.sau.com.au/forums/topic/485535-rp71c2-speed-sensor-help-please/#findComment-7990104 Share on other sites More sharing options...
GTSBoy Posted May 31, 2024 Share Posted May 31, 2024 32 minutes ago, WMDC35 said: R33 non turbo manual has the electronic speedo drive in the small box. Valid point. That would be true for R34 also. I should have known that because the 2nd small box I put in my car was an R33 one, and I had to swap my cable drive in for the sender!! Link to comment https://www.sau.com.au/forums/topic/485535-rp71c2-speed-sensor-help-please/#findComment-7990105 Share on other sites More sharing options...
EndZee Posted May 31, 2024 Author Share Posted May 31, 2024 So I’m looking for rb20det sensor or rb25de. Is this possible that ka24de/sr20 also could work? How much teeth is for small box sensor? 21? Does diameter size vary between these gearboxes? https://youtu.be/VPhkpdEH7Lg?si=uGF2tLuAM6Mb5LF2 Link to comment https://www.sau.com.au/forums/topic/485535-rp71c2-speed-sensor-help-please/#findComment-7990135 Share on other sites More sharing options...
WMDC35 Posted June 1, 2024 Share Posted June 1, 2024 R33 NA comes as rb25de or rb20e, so either of those, or r34 rb20de Link to comment https://www.sau.com.au/forums/topic/485535-rp71c2-speed-sensor-help-please/#findComment-7990153 Share on other sites More sharing options...
