It’s sitting in my garage waiting for me to swap fluids! I found some interesting information regarding ATB diffs offered by Quaife and spoke to a guy who went from a Tomei Trax 1.5 way to a quaife ATB 2 way… says he heard everything in the Tomei on the street and hears almost nothing on the ATB. Since that’s the first direct experience I’ve come across, I’ll go that route if the thicker fluid doesn’t alleviate things.
I understand it is a random problem, I was just hoping someone else may have encountered it before
You didn't have "no luck". No-one is going to be able to identify the very random problem that you have. You are going to have to do actual diagnostic work. Put a go pro under it and go for a drive. Run it on the dyno. Tape a microphone under the car in various locations until you get an increase in volume. Etc.
Yes the manual programming sequence doesn't work, I have tried it multiple times over the last 3 or 4 days. I have some OEM nissan keys from Amayama but cant get the car to enter programming mode. All the materials I have found describe it the same way and yes its more than inserting the key but anyone familiar with the method will know which one that is. It's here and here as two examples. I started looking at OBD2 type key or immobilizer programmers as an alternative but its a rabbit hole of different models and options with some reviews saying 'X doesn't do this but Y does'. Right now I think the Vident i705AU might work, but not sure and maybe a NT710 from Foxwell.
