Hi all,
Been working on my hks ss turbo setup and making around 540hp without doing a 2.8L stroker upgrade. I feel this is a safe level with the weak link rod screw bolts I heard. What is everyone else putting out safely? I’m running 1.4 bar right now max on 98. I think with the tomei stroker kit I will be able to max the turbos out at around 650hp crank safely.  My friends putting down 525whp with the garret 7s and stroker kit already.
What’s everyone’s thoughts?
I have added my first dyno runs yesterday that I recorded. Curve is super smooth with horse power delivery with twins. Thanks
https://www.sau.com.au/forums/topic/485537-max-horse-power-stock-internals/
3 hours ago, Sleepergm said:
Hi all,
The GTIII-SS turbos are not made for 650 hp crank. They just aren't going to do it. The turbine housing is smaller than the Garrett -7s. The turbo in general is smaller than a GT2860R-7, if it makes the same power as -7s you should be happy. Honestly I would be really happy with your results as far as power delivery goes. Hitting peak torque by 3500 rpm if that's actually happening in 4th gear in the real world is not normal for an RB26 at all. I have heard of people doing 2.8 strokers with GTIII-SS engines but I don't think I've ever seen a dyno sheet of it. I would be worried that the torque falls off faster than RPMs can rise so instead of getting a wider power peak you just shift the whole curve down 500-1000 RPM and end up with an engine that's no fun to rev out.
  • Like 1
Thanks for the info. With the 2.8L stroker kit what would be the best single turbo setup for around 700-750 drivable horsepower? As I think after that it’s going to be very aggressive power delivery.
It's a lottery, no one is going to be able to predict how much HP YOUR engine is going to handle as history has a huge part to play.
As examples though.
I have one rb26 on 630rwhp, running 16 years now at that level, track use, only a couple of times a year.
Another 790rwhp, about 2 years now, driven every weekend.
If i was to give you a "safe" number I would say 450rwhp on 98 and 550-600 on e85.
Seen plenty of motors pop with less though too :)
  • Like 1
I think you want an RB34 build at that point to go with a G30-770. Also if your dyno is reporting whp and not crank horsepower you should know your tuner is probably massaging the correction factors to make customers feel better. GTIII-SS and -7s are good for high 300 whp on pump gas, maybe just over 400 whp depending on the setup. E85 will push it into the mid 400 whp or so.
  • Like 1
I think the figures are pretty accurate as all my other cars are around the right hp readings as have done on multiple dynoes. However they are rwd cars so might mean the difference.
I am running every possible hks part also and a str exhaust … all new ecu. The mod list is endless. 😂 I’m ready for stroker and big turbo if I go that route.
1 hour ago, Sleepergm said:
My whp was 418whp and 518hp crank on 98 octane fuel. So decent numbers.
IMO I would stop there but it's up to you. At the power numbers you're asking about the stock 05U block will start showing issues. Even an N1 block might not be enough. PRP is trying to do blocks and heads that will be ready for big power right out of the gate but it remains to be seen whether any of that is any good. It might be great. It might be awful. It's hard to say until enough people have gotten their hands on one and run it for extended periods.
This is what I was looking at next:
https://www.z1motorsports.com/engines/tomei/tomei-rb26-28l-short-block-assemblies-p-45479.html
as we can’t bore the cylinders out in hk so better just buy the whole lot in one and install then retune. Everyone saying the weak link are the bolts holding the rods together. I already did valve springs, arp head bolts, hks racing coils, nismo fuel pumps and pressure regulators, injectors etc for the top of the engine.
https://www.platinumracingproducts.com/en-us/products/nissan-rb26-cast-blocks
This is the solution I was thinking of. I would stay away from Tomei USA, their quality is a question mark to me. If you want an engine machined in the US contact Club DSPORT: https://clubdsport.com/
Tomei JP is probably fine but I recall they stopped doing pre-assembled short or long blocks. In general it's pretty tough to get any kind of RB26 block at the moment with Nissan so severely backordered.
Yeah I heard the same. Might be hard to order one. But then I guess can go to hks or go to a more expensive n1 block with tomei. Guess will jump the hurdle once I get there next upgrade around. I can’t get work done in the states as the lead time will take for ever on top of shipping to Hong Kong.
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
