Hi all,
was wondering anyone upgrade these and what are their opinions? Worth the time to install for daily driver or just helpful for track cars. Or should just got with a full r34 transmission 6 speed swap. Are the lsd really neccessary with horse power over 600hp? Thanks
https://www.sau.com.au/forums/topic/485538-nismo-front-and-back-lsd/
What's your intended usage for the car?
GT-Rs already have a mechanical LSD at the back, provided the clutch packs are still in good condition, it should delivery 50/50 torque split between LHS & RHS rear wheels.
Wouldn't hurt to put in a helical front diff, however would avoid a clutch pack front if you want to keep it streetable.
  • Like 1
1 hour ago, Sleepergm said:
Hi all,
For street use I wouldn't bother with a clutch type LSD on the front especially on a mostly RWD car like the R32 GTR. It will affect steering feel and you're really not going to get much benefit out of it. If you insist on putting in a front LSD I would go with a Quaife or similar Torsen/helical LSD as that will have less impact on steering feel.
R34 6 speed swap is not really worth it IMO. If you don't swap the final drive on the front and rear differential the car will rev much higher on the highway. For 120 kph it will sit at 3700 RPM, perceptually higher because the factory tachometer reads a little high. Stock transmission it's closer to 3050 RPM for 120 kph. If you change the final drive ratios you will have to either change the gear on the vehicle speed sensor or use some kind of converter because the gauge cluster is taking RPM of the transmission output shaft, not the differential output shafts. Add in the cost and the fact that it's not actually that much stronger than an FS5R30A especially in hard use due to the specification of ATF and I've given up on the idea of using a Getrag 233 in these cars. It's just not worth it considering the huge cost.
If you want a stronger transmission build the FS5R30A. PAR Engineering supposedly will do whatever gear ratios you want. You can move things around so 1st and 2nd are not so clearly optimized for 0-100 kph acceleration. The gap between 2nd and 3rd is gigantic for autocross. OS Giken and a few other shops do this, take your pick.
  • Like 3
Counter opinon. Having both an OS gearset car and the getrag 6 speed, will take the 6 speed for the street all day long thanks. First gear on most gear sets are ASS, the bloody gear you spend heaps of time in on the street too.   I run the 4.11 and it is fine at 110, (not sure who gets to do 120)
I do find the gears a little short and doing a 3.89 setup.
Anyway back to your question, running stock LSD rear, love it. Tried an S15 helical rear, it was aweful. In the process of doing a quaife front on advice as part of the 3.89. Seems like a good option. Let you know :)
Car is 800awhp and mostly street.
  • Like 2
What’s wrong with 2.6 first gear? I’ve done lots of 2nd gear starts from almost a dead stop and it just requires more clutch slip. A 2.6 first gear would be easier than that. I feel like the stock first gear is only good for severe traffic congestion where you need to be able to do 5 kph idling in first gear. Out in the US 120 kph is a very normal speed to be doing on the highways. If anything it’s slow, I regularly get passed by CA highway patrol doing that kind of speed. Out in the desert and plains even 18 wheelers are doing 130-140 kph.
I would be less down on the Getrag if not for the fact that they cost north of 10k USD used and you’ll spend probably another 5k on a rebuild at least. I got my FS5R30A from Nissan for 1.5k USD. The cost of building one is maybe an extra 3-4k if you keep it reasonable. The final drive change to account for the 0.793 6th gear is also a pain to deal with.
  • Like 2
Please let me know how the quaife on the front goes… thanks
Will mainly be steering the car as tracking it in China would reduce its value a lot and mines a near mint condition v spec 2. Just weighing out the options for the next improvement. Thanks
Fair play on the 120k, sorry just live in nanny Aus.  High rpm on cruise would kill me too.
On the gears, its not just first, so beside the fact I really enjoy that nice punch you get when you accel in first. 2nd is all messed up in the gearsets too. Most people I know with gearsets(even sequentials) have to drop into 1st for tarmac rally slower corners as second gear is too low in rpm, its painful. Translate to the street, I am using a 2.3 gear out of a low speed turn, gearset you got a 1.7 second. I can tell you now between my two cars which one is a LOT more fun.
On a track its a different story, once the car is moving the gearset ratios are supreme, 1st gets you going on a big rpm launch, then 2nd is no issue for the corner speed on most tracks.
Yer the price sucks :( , old enough to remember these selling for $1500usd here in Aus.
  • Like 1
Helical front diff, refresh the rear mechanical if needed and enjoy life.
Save that money for a twin scroll, single turbo setup and modernisation of the car such as DBW, cruise control via DBW, canbus keypad etc.
  • Like 1
Will look into the helical front diff thanks.  Sounds like everyone just says keep the rear as is. 👍🏻
  • Like 1
PAR specifically offers stock ratios in their gearset and you could do whatever ratios are physically possible supposedly for no extra cost. I agree 6 ratios is better than 5, the factory 2nd gear is equivalent to the Getrag 2nd gear if you account for the differing final drive ratio though. The Getrag 3rd gear with a 3.916 final drive is equivalent to a 1.6 2nd gear in the FS5R30A.
I'm about to swap the transmission out on my car, I'm tempted to send the one I have now out for rebuild with the standard "cross ratio" gearsets out there to see if it really makes such a big difference the next time I pull the transmission.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
