Front Tyres on R34 GTR, fitment, etc, *question*
I have a question with regards to R34 GTR guards.
All the info here is quite old. Useful, but old.
At what point does the bumper itself become a clearance issue with wide wheels on a R34 GTR, specifically the part I've drawn in red here:
All of the info that people post about implies that 285 is as far as you'd go before scrubbing becomes an issue, but they speak of hitting the inner plastic liners, not the bumper itself.
Just how wide could you go if you took the liners out?
Has anyone done it? I have been messing with my own car and spacers and heavily cursed my lack of planning, but I might not feel so bad if there's actually no gains to be had by going a GTR guard and front bar combination for $5k+ of money I do not have after spending about that much already on my solution which now has problems. (Woo)
At least I now know why GTR guards and bumpers flare out like this over their GTT lesser cousins.
I feel that in 2024, someone has gone further and attempted to run 315's or somesuch on the front of a R34 GTR.
If you have, please post. If you're tried and failed for some other reason definitely post so I feel better about my mistakes :D
Pretty sure REAP3R (white 34 R) runs 305 x 30's on a 19x11 inch wheel. Stock guards by the look of it (minus liners i guess)
I don't know the answer with a 34, but for sure the standard bumper location is the limiting factor with a 32, that is where the larger diameter tyres I was trying to run were rubbing (noting I had already rolled the guard lip)
On 06/06/2024 at 5:50 AM, ianp said:
I had 295s on mine when I had a 34 and they didn't rub and that was with Nismo coilovers
Do you have any pictures? Love to see chunky tyres on our cars.
Guards were made for 300mm slicks so let's see them chonky bois!
17 hours ago, ianp said:
They were 19*11 +25 with a 10mm spacer to clear the shocks. Tyres from memory were 295/35/19
One of my questions about this was how/if the R34 GTR strut is different to the R34 GTT (I mean it could easily be).
In my car, the 18x9+30 feels like it is 0.0001mm from the strut with a 265 on it. Given a 10.5 +15 is closer to the strut than an 18x9+30, it would certainly foul... surely
I am encouraged that a 19x11+25 would need a spacer to clear the R34 GTR suspension arms at least!
It only needed a spacer because it was the Nismo struts with the external resevoir, if it had been regular coilovers, it probably would have been ok
That's the thing I don't get is the issue is not the shocks in the 34 GTT......
I assume the GTR geometry is different here.
SQUARE PEG IN ROUND HOLE WHY WON'T YOU WORK!
 Share
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
