Front Tyres on R34 GTR, fitment, etc, *question*
I have a question with regards to R34 GTR guards.
All the info here is quite old. Useful, but old.
At what point does the bumper itself become a clearance issue with wide wheels on a R34 GTR, specifically the part I've drawn in red here:
All of the info that people post about implies that 285 is as far as you'd go before scrubbing becomes an issue, but they speak of hitting the inner plastic liners, not the bumper itself.
Just how wide could you go if you took the liners out?
Has anyone done it? I have been messing with my own car and spacers and heavily cursed my lack of planning, but I might not feel so bad if there's actually no gains to be had by going a GTR guard and front bar combination for $5k+ of money I do not have after spending about that much already on my solution which now has problems. (Woo)
At least I now know why GTR guards and bumpers flare out like this over their GTT lesser cousins.
I feel that in 2024, someone has gone further and attempted to run 315's or somesuch on the front of a R34 GTR.
If you have, please post. If you're tried and failed for some other reason definitely post so I feel better about my mistakes :D
Pretty sure REAP3R (white 34 R) runs 305 x 30's on a 19x11 inch wheel. Stock guards by the look of it (minus liners i guess)
I don't know the answer with a 34, but for sure the standard bumper location is the limiting factor with a 32, that is where the larger diameter tyres I was trying to run were rubbing (noting I had already rolled the guard lip)
On 06/06/2024 at 5:50 AM, ianp said:
I had 295s on mine when I had a 34 and they didn't rub and that was with Nismo coilovers
Do you have any pictures? Love to see chunky tyres on our cars.
Guards were made for 300mm slicks so let's see them chonky bois!
17 hours ago, ianp said:
They were 19*11 +25 with a 10mm spacer to clear the shocks. Tyres from memory were 295/35/19
One of my questions about this was how/if the R34 GTR strut is different to the R34 GTT (I mean it could easily be).
In my car, the 18x9+30 feels like it is 0.0001mm from the strut with a 265 on it. Given a 10.5 +15 is closer to the strut than an 18x9+30, it would certainly foul... surely
I am encouraged that a 19x11+25 would need a spacer to clear the R34 GTR suspension arms at least!
It only needed a spacer because it was the Nismo struts with the external resevoir, if it had been regular coilovers, it probably would have been ok
That's the thing I don't get is the issue is not the shocks in the 34 GTT......
I assume the GTR geometry is different here.
SQUARE PEG IN ROUND HOLE WHY WON'T YOU WORK!
 Share
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
