Never ending fuel pump drama
4 minutes ago, joshuaho96 said:
Too cheap? I think it's pretty expensive.
Oh, I saw $150 USD and thought, yeah I'd pay that to not have to stuff around with a relay, flyback diode, pull up resistors or whatever else needs to be setup to run PWM.
I'm like a 100% pure Haltech customer, I just want to buy another box, plug the wires into it and have it all work lol.
  • Like 1
  • Haha 1
It's not that expensive for what it does. It is a programmable thingo that allows you to do a wide range to tasks. It is expensive compared to just buying the bits needed to add an SSR into the fuel pump control.
And, given that you have an ECU that should be capable of doing teh actual control, all you really need is an SSR (and heatsink), and some wiring anyway.
  • Like 2
Link has a great forum topic on the Dorman 902-310.
Just do the same for your fuel pump and enjoy life. I would run it at 1kHz+, the higher the better.
I'm running mine at 1kHz but that's due to the Crydom's limits.
https://forums.linkecu.com/topic/23999-g4-monsoon-dorman-902-310-cooling-fan-pwm/
  • Like 2
21 hours ago, Dose Pipe Sutututu said:
Another another another option (I might do this one day, also has a fly back diode, built in heat sink, will happily run at  5kHz) is the Dorman 902-310
That's a neat unit, was looking at running the traditional setup for the race car but will look at using these now.
  • Like 1
On 6/29/2024 at 10:29 PM, Butters said:
Melted into the plastic, example one of the two, had washer either side.
I've had this happen with some cheaper kits and found the efihardware ones don't do this.
I would go be pwm the pump no way need it at 100% all the time.
  • Like 1
Mine looked exactly like this too. I found that if you didn't have them tightened to 100000 ft/lb, they must create some sort of arcing, and melt.
+1 on the FPG fuel hat!
funnily enough I tried to PWM control my fuel pump (Walbro/Ti Auto 450l/hr) through the PDM and it didn’t like it. Scott from Haltech said they don’t like it? So I just run mine at 100%.
I think the PDM outputs (the ones that can actually output big power) are not intended to be driven like that. They're either on or off, switched only at a low rate. To do PWM you need to use an ECU output that is PWM friendly (ie, able to be run at high frequency) and drive a separate SSR, instead of trying to thrash the (presumably) SSRs in the PDM.
  • Like 1
Well that explains it!
1 hour ago, Murray_Calavera said:
For example, the Walbro 525 (F90000285) is the factory fuel pump in the Hellcat which has PWM from factory. These pumps like PWM, it extends the life of the pump.
I think he meant Haltech meant that the Haltech PDM doesn't like driving loads with PWM. Not that the pumps don't like it.
Think about the heatsinks that we strap onto SSRs for just handling a single PWM load. Then picture how much heatsinking is visible on a Haltech ECU or PDM. None, right? So it's no surprise that they don't want to run PWM loads directly.
55 minutes ago, Murray_Calavera said:
Just checking, with this would you need anything else to get yourself up and running? Do I need a flyback diode, pull up resistors or anything else?
I wouldn't think you would need a flyback diode, as it's an OEM replacement parts for a fan controller/relay on a Dodge.
Another tried and tested option are the Volvo XC90 (or similar) fan controllers.
@Dose Pipe Sutututu
Sounds good.
Just double checking with the pull up resistor indicated in haltech's info sheet for their SSR - https://www.haltech.com/product/ht-030202-solid-state-relay-100-amp/
I'm guessing that would only be if the ECU did not have an internal pull up resistor? Their instructions are pretty strongly worded lol "1K pull-up resistor MUST be fitted."
That SSR is actually the same (or similar) as the Jaycar 100AMP SSR (which I use).
They suggest the resistor to stop the SSR turning on when the ECU turns off (I believe). I personally don't use the resistor as I use the 5V output from the ECU to supply power to the SSR. I do however run a flyback diode, the old Haltech documentation was wrong too and didn't specify the fly back, I mentioned it to a few of their staff and they eventually added it in.
  • Like 1
17 hours ago, Murray_Calavera said:
Ah ok, yeah I thought he meant the pumps didn't like it.
Haltech sell a 100 amp SSR, I'm surprised they didn't just sell him one of those.
Honestly, I did think the PDM could do it and thought Haltech told me the pump didn’t like it. But after re-reading the emails and comments above, I clearly misunderstood lol.
  • Like 1
 Share
    • Awesome stuff. I should sell my R32 and get a V37 RedSport haha. Looking forward to this build.
    • So, first things first, it's had a service for all fluids (2x coolant as it has air/water heat exchangers instead of air/air), new air filters (they were terrible, and one was pinched when installed by NIssan's "technician"). Also, both the boot and bonnet gas struts were shot, so ebay sorted some new ones, the jack handle kept me alive for the first service It needs tyres (more to come on that...) and the brakes are horribly grabby, looks like they've been badly glazed sitting around in Sydney traffic. On the bright side there are no obvious leaks and it runs well. The car goes well with 300kw (stock, claimed, I'll put it on a dyno soon), does good skids and handles reasonably well eg in long medium g corners. It is no cruiser like the Fuga though and is noticeably jiggly on the average (poor) rural road and terrible on corrugated dirt.  I'll get some road/race shocks in it shortly which should help.
    • So, for those following along at home, I've had the R32 up on stands for a while since a minor incident in the last rally, which required a new rear quarter panel to be welded in after the car had been (pretty much) put back square again. The problem is of course, that some R32 GTR stuff is simply not available (eg front guards) and other things are either expensive (second hand) or very expensive (nismo heritage).   In the end I've decided to try out a v37 with some track days, hill climbs etc before going ahead with modifying it for race/rally like the old GTR. To do so I've picked up an ADM Infiniti Q50 Red Sport, rather than a JDM car which offers much better value but might lead to complexities when I discuss spec with the production racing guys. In the meantime it will be my daily (well, more like weekly) driver, mostly highway use to Canberra or Sydney. BTW yes, I did notice it is auto-only, and yes I did know the Z comes with the same motor in manual. Big issue with the Z for me is that it is unlikely I can meet the new rally cage clearance requirements in that chassis so I've gone the 4 door/auto route The colour isn't great for rural lyf, and neither is having a sunroof for racing, but the Q50 market is small and it is what it is. Also...can't say I really like the shape much either, the front is OK but from the rear it is a dead ringer for a mazda 6
    • Ahh yes looks like I’m playing with a new cock on the weekends. Thanks for the information @soviet_merlin I’ll search for it later on and try to get it shipped. Looks like it won’t happen this weekend regardless. But the coolant looks fine so far (no floaties of concern). And waiting another week will slow down my money hole 😂
    • I don't know whether that one should be reused or not. But here's one way to find the part. Go to https://nissan.epc-data.com and use frame number or the menus to drill down to the parts for your specific car. Looks like it is under 'Body parts -> 214 radiator'. See for example the respective part for my Stagea. Looks like it's called drain cock packing, and at least for mine it is part number 2148118000. Searching for that then gives you various places where you can buy it. Amayama can be a bit slow, so it's worth searching around. I'd make sure it's the correct one for yours. At least from amayama it looks pretty generic and fits a ton of cars. And if anyone asks what you did on the weekend, you can tell them that you put a new cock on the car
