Never ending fuel pump drama
4 minutes ago, joshuaho96 said:
Too cheap? I think it's pretty expensive.
Oh, I saw $150 USD and thought, yeah I'd pay that to not have to stuff around with a relay, flyback diode, pull up resistors or whatever else needs to be setup to run PWM.
I'm like a 100% pure Haltech customer, I just want to buy another box, plug the wires into it and have it all work lol.
  • Like 1
  • Haha 1
It's not that expensive for what it does. It is a programmable thingo that allows you to do a wide range to tasks. It is expensive compared to just buying the bits needed to add an SSR into the fuel pump control.
And, given that you have an ECU that should be capable of doing teh actual control, all you really need is an SSR (and heatsink), and some wiring anyway.
  • Like 2
Link has a great forum topic on the Dorman 902-310.
Just do the same for your fuel pump and enjoy life. I would run it at 1kHz+, the higher the better.
I'm running mine at 1kHz but that's due to the Crydom's limits.
https://forums.linkecu.com/topic/23999-g4-monsoon-dorman-902-310-cooling-fan-pwm/
  • Like 2
21 hours ago, Dose Pipe Sutututu said:
Another another another option (I might do this one day, also has a fly back diode, built in heat sink, will happily run at  5kHz) is the Dorman 902-310
That's a neat unit, was looking at running the traditional setup for the race car but will look at using these now.
  • Like 1
On 6/29/2024 at 10:29 PM, Butters said:
Melted into the plastic, example one of the two, had washer either side.
I've had this happen with some cheaper kits and found the efihardware ones don't do this.
I would go be pwm the pump no way need it at 100% all the time.
  • Like 1
Mine looked exactly like this too. I found that if you didn't have them tightened to 100000 ft/lb, they must create some sort of arcing, and melt.
+1 on the FPG fuel hat!
funnily enough I tried to PWM control my fuel pump (Walbro/Ti Auto 450l/hr) through the PDM and it didn’t like it. Scott from Haltech said they don’t like it? So I just run mine at 100%.
I think the PDM outputs (the ones that can actually output big power) are not intended to be driven like that. They're either on or off, switched only at a low rate. To do PWM you need to use an ECU output that is PWM friendly (ie, able to be run at high frequency) and drive a separate SSR, instead of trying to thrash the (presumably) SSRs in the PDM.
  • Like 1
Well that explains it!
1 hour ago, Murray_Calavera said:
For example, the Walbro 525 (F90000285) is the factory fuel pump in the Hellcat which has PWM from factory. These pumps like PWM, it extends the life of the pump.
I think he meant Haltech meant that the Haltech PDM doesn't like driving loads with PWM. Not that the pumps don't like it.
Think about the heatsinks that we strap onto SSRs for just handling a single PWM load. Then picture how much heatsinking is visible on a Haltech ECU or PDM. None, right? So it's no surprise that they don't want to run PWM loads directly.
55 minutes ago, Murray_Calavera said:
Just checking, with this would you need anything else to get yourself up and running? Do I need a flyback diode, pull up resistors or anything else?
I wouldn't think you would need a flyback diode, as it's an OEM replacement parts for a fan controller/relay on a Dodge.
Another tried and tested option are the Volvo XC90 (or similar) fan controllers.
@Dose Pipe Sutututu
Sounds good.
Just double checking with the pull up resistor indicated in haltech's info sheet for their SSR - https://www.haltech.com/product/ht-030202-solid-state-relay-100-amp/
I'm guessing that would only be if the ECU did not have an internal pull up resistor? Their instructions are pretty strongly worded lol "1K pull-up resistor MUST be fitted."
That SSR is actually the same (or similar) as the Jaycar 100AMP SSR (which I use).
They suggest the resistor to stop the SSR turning on when the ECU turns off (I believe). I personally don't use the resistor as I use the 5V output from the ECU to supply power to the SSR. I do however run a flyback diode, the old Haltech documentation was wrong too and didn't specify the fly back, I mentioned it to a few of their staff and they eventually added it in.
  • Like 1
17 hours ago, Murray_Calavera said:
Ah ok, yeah I thought he meant the pumps didn't like it.
Haltech sell a 100 amp SSR, I'm surprised they didn't just sell him one of those.
Honestly, I did think the PDM could do it and thought Haltech told me the pump didn’t like it. But after re-reading the emails and comments above, I clearly misunderstood lol.
  • Like 1
 Share
    • The point of all that for me was to get to the PDM (yes, v37 is as fancy as a haltech) which is between the battery and the front inner guard.  In there, pins 80 and 81 on connector E125 are for hi beam according to the USDM manuals. I chose to intercept the high beam signal there as it is next to the battery and firewall so it is a good place to mount the fuse/relay for the LEDs. Unfortunately because you can't access the PDM with the battery in the car, it is difficult to test those wires are correct. The fuses for Left and Right high beam are marked on the PDM cover, so I checked continuity from the fuses to those pins with a multimeter, and it seems to be right. From here I need to splice a wire into one of those 2, and run it into the cabin for a switch, then run the trigger wire back to that general location for the relay. So, I removed the driver's side guard liner to check out where the wiring leaves the engine bay and enters the cabin.  Turns out, that does not happen behind in guard liner at all....waste of time, nothing is routed through there, so that was another 5 pin clips, 4 screws and a bolt of wasted effort All of the wiring is actually run across the separate compartment between the engine bay and the cabin under the cowling...so off with the windscreen wipers after all....
    • So....the good news is you don't have to remove the windscreen wipers to replace the 12v battery in a v37 (just). You do however have to remove: 1. Battery area cover (un clips) 2. Battery area trim (pin clips) 3. Nav side windscreen cowling (more pin clips, plus the trim between the cowling and the front guard, and half of the cowling to bonnet seal All of that gets you to here, with clear access to the battery While there, it is worth clearing out the leaves and dirt that run from the cowling into that well, my car had a lot of crap there and it is a guaranteed future rust hotspot
    • Onto trickier matters....this time of year a LED light bar makes a massive difference to avoid skippies etc, so that was the first main priority. Unfortunately unlike both the Cima and the Fuga, there is no chance for a large central light bar inside the grille due to all of the redsport bits already there (intercooler radiator, extra water pump, sonar stuff). So this time I've gone a pair of 8" light bars which does have the benefit that they can be angled outwards a little as well. First, bumper needs to come off as there is no way to access the space behind the grill with it in place. Unlike the R32 which is (now) held on with 2 screws, the v37 had about 30 pin clips, 20 bolts and also 6 clips holding the damn thing on. Basically you remove the intake (clips), the top side covers (nasty clips) to get at 2 bolts, the front of the undertray (about 15 bolts and 3 clips), the front side inner guard covers (3 bolts and a couple of clips each) to get at the bolts at the rear of the bump in the wheel well, and then 3 clips near the headlight (outside, then under headlight, then above headlight) As part of that process the car got its first "race" mod so you can get at the top bumper bolts without removing the trim. There are also about 8 different electrical connectors which are in grave danger of being cut and replaced by one multi pin deutsch connector one day. On the bright side it is clear the bumper had never been off by how tight the connectors were. Once off, you can see there is very little space to work with. The lower section was not an option as the angle to the road would suck, plus the sonar module would push everything too far to the centre So I mounted the left side bracket to just clear the water pump (a miss is as good as a mile, they say) and the horn has been moved backwards too. The brackets on these Narva lights were a nice height to clear the front reo, and I just drilled and rivnut-ed into the reo (angle drills suck, but at least it made the job possible) With both mounted Minor adjustments to horn locations but everything else cleared. Those horns may well get moved / one deleted depending on how the cooling is on hot days, they were moved well to the side in the R32 Next, onto the wiring which will be a pain...
    • OK, next order of business, very much not important but I didn't like how like how it looked (and, we can pretend it restricts airflow if that makes this better). Both the front number plate, and more importantly the holder are pretty ugly. Step1, replace bent old plate with new one in blue cf style with new values Step2, unlike the Leaf where the bumper was flat enough to remove the holder altogether and just mount it on the bumper, with the v37 I decided to chop the hell out of the mount to retain the flat mounting surface. Step 3, much better (needs black bolts I think)
    • If you are selling an R32 GTR, you can buy 3 or 4 v37s Redsports..... Anyway, a few more services/mods for daily use are the first order of business. I'm using the 2015 Q50 (LHD) workshop manuals from Nicoclub and they seem pretty much right, but a search didn't turn up any mention of the term "glove" so I could work out how to properly change the cabin filter for the AC. After some stuffing around, turns out Nissan now call it a "grove" box. Anyway, for anyone who does want to change their cabin filter : 1. Half open the glove box then push upwards each side to release bottom hinges, then twist sideways to remove opening stoppers, then pop off dampener string LHS 2. Unclip the cover behind, then unclip the cover behind that 3. Cabin filter is now readily accessible, note the airflow arrow points downwards. It seems loose in the space but note the cover has tabs that will push it up when you install the cover This time the filter was basically new so I've just marked it with the current date and reinstalled, and the aftermarket replacement I bought Wesfil (WACF-0177) is into the parts box   I really recommend checking this in any car that is new to you, they are normally really grotty
