6 hours ago, Dose Pipe Sutututu said:
Looks good but wow the price tag
Does it seem too cheap?
If this thing does what is says on the tin, would this be all I need to setup PWM for the fuel pump?
4 minutes ago, joshuaho96 said:
Too cheap? I think it's pretty expensive.
Oh, I saw $150 USD and thought, yeah I'd pay that to not have to stuff around with a relay, flyback diode, pull up resistors or whatever else needs to be setup to run PWM.
I'm like a 100% pure Haltech customer, I just want to buy another box, plug the wires into it and have it all work lol.
  • Like 1
  • Haha 1
It's not that expensive for what it does. It is a programmable thingo that allows you to do a wide range to tasks. It is expensive compared to just buying the bits needed to add an SSR into the fuel pump control.
And, given that you have an ECU that should be capable of doing teh actual control, all you really need is an SSR (and heatsink), and some wiring anyway.
  • Like 2
Link has a great forum topic on the Dorman 902-310.
Just do the same for your fuel pump and enjoy life. I would run it at 1kHz+, the higher the better.
I'm running mine at 1kHz but that's due to the Crydom's limits.
https://forums.linkecu.com/topic/23999-g4-monsoon-dorman-902-310-cooling-fan-pwm/
  • Like 2
21 hours ago, Dose Pipe Sutututu said:
Another another another option (I might do this one day, also has a fly back diode, built in heat sink, will happily run at  5kHz) is the Dorman 902-310
That's a neat unit, was looking at running the traditional setup for the race car but will look at using these now.
  • Like 1
On 6/29/2024 at 10:29 PM, Butters said:
Melted into the plastic, example one of the two, had washer either side.
I've had this happen with some cheaper kits and found the efihardware ones don't do this.
I would go be pwm the pump no way need it at 100% all the time.
  • Like 1
Mine looked exactly like this too. I found that if you didn't have them tightened to 100000 ft/lb, they must create some sort of arcing, and melt.
+1 on the FPG fuel hat!
funnily enough I tried to PWM control my fuel pump (Walbro/Ti Auto 450l/hr) through the PDM and it didn’t like it. Scott from Haltech said they don’t like it? So I just run mine at 100%.
I think the PDM outputs (the ones that can actually output big power) are not intended to be driven like that. They're either on or off, switched only at a low rate. To do PWM you need to use an ECU output that is PWM friendly (ie, able to be run at high frequency) and drive a separate SSR, instead of trying to thrash the (presumably) SSRs in the PDM.
  • Like 1
Well that explains it!
For example, the Walbro 525 (F90000285) is the factory fuel pump in the Hellcat which has PWM from factory. These pumps like PWM, it extends the life of the pump.
I think he meant Haltech meant that the Haltech PDM doesn't like driving loads with PWM. Not that the pumps don't like it.
Think about the heatsinks that we strap onto SSRs for just handling a single PWM load. Then picture how much heatsinking is visible on a Haltech ECU or PDM. None, right? So it's no surprise that they don't want to run PWM loads directly.
On 7/3/2024 at 9:35 AM, Dose Pipe Sutututu said:
Dorman 902-310
Just checking, with this would you need anything else to get yourself up and running? Do I need a flyback diode, pull up resistors or anything else?
I wouldn't think you would need a flyback diode, as it's an OEM replacement parts for a fan controller/relay on a Dodge.
Another tried and tested option are the Volvo XC90 (or similar) fan controllers.
@Dose Pipe Sutututu
Sounds good.
Just double checking with the pull up resistor indicated in haltech's info sheet for their SSR - https://www.haltech.com/product/ht-030202-solid-state-relay-100-amp/
I'm guessing that would only be if the ECU did not have an internal pull up resistor? Their instructions are pretty strongly worded lol "1K pull-up resistor MUST be fitted."
That SSR is actually the same (or similar) as the Jaycar 100AMP SSR (which I use).
They suggest the resistor to stop the SSR turning on when the ECU turns off (I believe). I personally don't use the resistor as I use the 5V output from the ECU to supply power to the SSR. I do however run a flyback diode, the old Haltech documentation was wrong too and didn't specify the fly back, I mentioned it to a few of their staff and they eventually added it in.
  • Like 1
17 hours ago, Murray_Calavera said:
Ah ok, yeah I thought he meant the pumps didn't like it.
Haltech sell a 100 amp SSR, I'm surprised they didn't just sell him one of those.
Honestly, I did think the PDM could do it and thought Haltech told me the pump didn’t like it. But after re-reading the emails and comments above, I clearly misunderstood lol.
  • Like 1
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
