7 hours ago, Murray_Calavera said:
The ring terminal is slightly larger then the stud, I would not describe those two as making good contact with each other. My assumption was, the good contact comes from the 2 washers on either side of the ring terminal making a good connection, and the washers make a good connection with the nut, which makes a good connection with the stud. I'm guessing this was an incorrect assumption?
This is the entire issue.
The stud should have a ringland on it, such that the stud metal, is also the same piece as attached to the ringland.
Think of it this way, take an actual bolt, turn it upside down.
The head of the bolt, is the ringland, and it is all part of the stud, so you put your ring crimp over it, a washer, and bolt it down.
Because you've got a stud with not metal landing, all of your real electrical connection, is through the threads in your nut to stud. Add to that, your nut is a nylock, so it isn't even necessarily all metal to metal contact.
But on a 6mm stud, your thread depth is probably 0.5mm probably a 1mm pitch, and being about 4mm of nut height.
That all equates to f**k all quality contact area. Not to mention, all the other joints in that area adding tiny resistances which all add up to bad heat!
You're going wire to crimp, crimp to washer, washer to nut, nut to stud, stud to nut, nut to washer, washer to crimp, crimp to wire. 8 joints in a small area, each with a small resistance.
If each joint adds 0.01ohm, that's 0.08ohm (basically immeasurable on most digital multimeters, you need a 4 wire measurement).
At 25amp, 0.08ohm is giving you a 2V drop.
2V, at 25amp, is 50watts of power. Where is all that power going? Heat.
You can now get someone else to go do the mafs on your stud and specific heat, and you'll start to realise why shits melting.
Even if you say I've way overestimated the resistance by a factor of 10, a 5w power input constantly as heat, is pretty high too and that's on 0.008ohms!
Get a good stud kit, that has a metal landing. Get good quality crimp with plenty of metal in the ring.
PS those JayCar ring terminals have the thinnest little ring. That area that GTSBoy indicates is one of the more meaty areas of the ring terminal!
  • Like 3
Ok, I've just ordered the high amp flanged kit from EFI Hardware.
Once it's installed, I'll go for progressively longer/harder drives and I'll check the temp of the terminals with the heat gun.
If there are any issues with temp, I'll drop in the Walbro 460 which should draw about 5 less amps and I'll repeat the process checking temps.
Also I'll make sure to take some high res photos of my crimps this time =P
I want to see crimps better than what would be minimum standard for the now dated International Space Station.
Street GT-Rs now have better wiring than Space X Falcon Heavies
  • Like 1
Put up photos of the crimps you're planning to use. Let us critique them 😛
But seriously post them up before you use them
  • Like 1
Weird that everybody thinks the terminals wouldn't work. I've had this style set up running on a 33 GTR since 2017 and don't have any fuel pump or heat issues, this is with dual relays and dual fuel pumps. I believe I used the EFI Hardware terminals listed above.
Because he's using a different product, designed different, works different. Can create a problem.
I am wondering how much the plastic hat plays into this.  Both of mine melted more opposite the wire crimp. Tried the efihardware ones , double washers , better eye terminals.  The seat of the plastic ring inside the metal hole is very thin 1mm or so and you are putting through a threaded bolt, which can cut the plastic, won't take much for some conductivity to occur in a metal fuel hat that is earthed.
Amp draw of pump is going to be a variable here too.  many things that impact that.
2 hours ago, Dose Pipe Sutututu said:
I'm going to sound like a broken record now, PWM your pump and you won't have this issue. Unless you're a speed boat and on WOT for minutes on end.
I promise it will get done as soon as I can, but that is still probably 3 months away.
I honestly think you should move it up by whatever priority possibly.
The time you're spending chasing this issue could be better spent doing PWM and resolving it fully.
  • Like 3
Update time, the Efi Hardware bulkhead terminals are in. The quality of the kit is leaps and bounds better compared to the Efi Solutions/Taarks kit. I was not happy with the Taarks kit, however I am very happy with the Efi Hardware kit so far. Being able to torque down the plastic insulator is a huge help. The longer post and jam nuts also make life easier.
I didn't bend the eyelet terminals 90 degrees to fit inside the bulkhead this time. I performed some surgery to the bulkhead to fit the terminals without bending them (in case the bend increased resistance in the terminal).
Unfortunately I didn't have time to drive the car, but letting it idle for about 10 minutes and the power terminal went from about 13 degrees to 16 degrees.
I'll update again after I've taken the car for a good shakedown to check temps.
As promised, I have taken some photos so my crimps can be judged by all.
Crimps were made with Delphi crimper (part number 12085271)
Heat shrink is Raychem RW-200-E recovered at 170 degrees.
  • Like 3
Took the car for a hard drive (the same drive that melted the Taark kit) and a couple of casual drives today. The terminal temps appear to be tied to ambient temps.
After each drive, including the hard drive, the terminal temps were always within 3 degrees of the other metal surfaces in the boot. Everything appears perfect so far.
I suppose the next real test will be when I drive down for WTA, I'll check the temps at each fuel stop and see if extended drives change anything.
(Just waiting for, see it was the crimps all along! Pretty crimps now and no issues, must be the crimps! lol)
  • Like 2
26 minutes ago, MBS206 said:
What are the ring terminals you used?
The ones that came with the kit -
https://www.efihardware.com/products/3194/submersible-bulkhead-terminals-hex-head
I told myself a few times, take a photo of the ring terminal with a ruler for scale. But then I didn't.
Suppose the most important bit is it's all sized appropriately (ring terminal is the same size as the post), this photo is a good example -
  • Like 1
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
