Hi i do buy a aftermarket headlight on ebay. For v35 skyline coupe. I know that its a plug and play and just use the old low beam light and balast from old headlight.
But my problem is i dnt have knowlage on car and electrical thing. And the head light getnon ebay is the wire for halo ring light is not connected. I talk to the seller and he said that. What white and black wire for halo robg light is need to connect to RDL. Running day light.
Anyone here can tell me how to connect it to Rdl? Which wire is yhe RDL?
https://www.sau.com.au/forums/topic/485559-need-help-about-headlight/
Just checking; you are buying an aftermarket headlight for your V35, and the new headlight comes with a daylight running light that you want to wire in?
You have the option of just not wiring the DRL in, and the new headlight will work like the old.
If you want the DRL to work you will have to wire it in on the car as it wasn't delivered with one. Best way is to add a Normally Closed or Changeover relay in the car, and wire:
87a to both DRL power wires
30 to a fused ignition power source
86 to earth
85 tap into the power wire that goes to the low beam headlight
Note, you cannot use the much more common Normally Open relay for this, you need the DRL to turn off when the headlight is on and vice versa.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
