Can anyone shed some insight on this Turbo?
The previous owner told me that he had a shop replace the old turbos with these. https://www.enjukuracing.com/products/garrett-rb26dett-gruppe-n-turbo-upgrade.html
Anyone know anything about them?  Looks like they are just GT2860R's? Not sure why they are renamed Grup-N...
Does the compressor wheel look like they are in okay condition?
Group N is a type of limited modification production rally, I agree they ware probably just -5s or similar. You really need the details from the tag on the core to tell, the housings don't tell you much because they can be machined to suit many cores.
For checking the compressor, all you need is to see no physical damage. The amount of movement in the shaft (side to side and forward/backward) is what matters
Interesting. I never made the connection on the Group N. Always read it like "gruppin".
What's the difference between -5 and -7?
On 6/9/2024 at 1:19 AM, r32-25t said:
The 5 is bigger then the 7
I never cared for twins but whenever these conversations came up, I always presumed the higher number represented a larger turbo. Learn something new everyday.
From now on read it as minus 5 and minus 7 instead of dash, and you're correct...
The -9 is absolutely regarded as the best choice lol. It's a 'better -7' with -5 and -10 being too big.
There's probably better twins nowadays, but just throw a single on and that sums up about 30,000 posts on this topic.
I will also have to claim the defence that I have never really cared about twins. I must be mis-remembering that people preferred the larger power of the -7s over the better matched setup of the -9s.
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
